跳转到主内容
加入维修社区 - 创建账户
Lenovo ThinkPad T500。这是一款于 2008 年 7 月推出的商务笔记本电脑。这款 15.4 英寸笔记本电脑可配置 2.26GHz 的 Intel Core 2 Duo P8400 处理器,最高可升级至 2.8GHz 的 Intel Core 2 Duo T9600 处理器(或 3.06GHz 的 Core 2 Extreme),并可选择 Intel 集成显卡或 ATI 可切换显卡。
Why is my computer getting so warm?
After 30 minutes of use, the laptop is very warm on the bottom and is uncomfortable to have on my lap. What's going on?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
There could be several reasons your laptop is getting hot. First off, laptop is a bit of a misnomer--they get hot and are meant to be used on a desk. Secondly, this laptop is a good 7 years old at this point, when was the last time (if ever) it had a thorough cleaning done on it?
Start with the basics and clean it out, new thermal paste, etc. Then if you are still experiencing abnormal heat issues (ie, burning your flesh), then there are some other issues at play here. If it is heating up after 30 minutes, though, probably needs a good cleaning.
这个答案有帮助吗?
得分 3
添加一条评论
Use your laptop on a Hard surface so the fans and case can dissipate the heat the right way. If you use it on your lap you have your body heat + the laptop heat, which will make it hotter.
http://gadgetwise.blogs.nytimes.com/2009...
这个答案有帮助吗?
得分 0
添加一条评论
Hi! You may have a problem with your fan. Try to clean your fan with a compressed air can.
If the problem persists, take a look at the Troubleshooting page to diagnose your exact problem.
Lenovo ThinkPad T500 Troubleshooting
这个答案有帮助吗?
得分 0
添加一条评论
its probably because u are not cleaning our laptop at all. or even trying to clean most of it.
这个答案有帮助吗?
得分 0
1条评论:
Does like opening the laptop and cleaning some dust with air blower and stuff help run the laptop smoother?
完成的
添加一条评论
添加你的答案
Nickie Gurney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 7,200
