跳转到主内容
加入维修社区 - 创建账户
这款 16 GB 的 Oppo Find 7a 发布于 2014 年 4 月,是 Oppo Find 7 的低配版。要区分 Find 7a 和 7,请取下后盖及电池。在电池放置在手机内部的位置,应该有两张序列号贴纸,上面印有 X9000。
change lens back camera
How can i change the lens of the back camera of my oppo find 7a??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
It isn't very hard. You can buy lens replacement on aliexpress or another Chinese site. To replace lens you have to follow these steps:
1. Take out back cover
2. Remove battery
3. Remove SD card
4. Remove all Phillips screws from back of the phone (some might be hidden under rubber caps - see other guides with photos .
5. Pry open the internal back chassis starting from a place near power button (credit card is a great tool for it. Don't use anything metal)
6. The lens is glued to the part you just pried open.
9. Detach the lens (well in fact it is a glass cover with UV filter) by applying some force from internal side of the back chassis to the glass - it should be quite easily pushed outside of the back chassis
10. The replacement lens should come with a glue ring.
11. Apply the glue ring to the side of the lens marked by white dot. Be careful to align it properly before applying. You don't want to make lens dirty, especially from the side facing internals of the phone.
12. Put the lens in the hole, glue down.
13. If required clean the lens from inside. You won't be able to do it later. Make sure there is no trace of glue, dirt, smudges or dust particles.
14. Put the back chassis in place. Press it until it clicks in place.
15. Reapply the screws
16. Insert SD card
17. Insert battery
18. Reattach back cover
Congrats, you just did great!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rudydellefave 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 1,678
