跳转到主内容
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
20 个问题 查看全部
black screen and 4 beeps
No picture want start, black screen and 4 beeps
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
Kissah Davis, 4 beeps on your Dell are for a Memory read / write failure. This could be caused by a bad memory module. First you should try to reseat it. To do that you fully open the securing clips, align the notch on the bottom of the module with the crossbar in the connector, place several fingers on top of the module and firmly push the module down into the slot, until the module snaps into position. If the module is inserted correctly, the securing clips will snap into the cutouts at each end of the module.
这个答案有帮助吗?
得分 3
1条评论:
After I'v done the laptop still has black screen BUT no beeps
完成的
添加一条评论
check screen.....press d and power button
这个答案有帮助吗?
得分 0
添加一条评论
that sounds like a power supply unit problem get a can of blow-out and blow it out real good.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kissah Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 7,957
