The spin cycle doesn't work, How can I fix it?
I have an old belt drive Kenmore 70 Series washer. The water drains from the tub, but it will not spin. The motor operates and the belt turns, but the tub does not spin. I have seen YouTube videos on how to fix the motor coupling on a direct drive washer, but I cant find any info on a belt drive washer. Does anyone have any advice?
Thanks
2条评论
Check your clutch and add ATF to the transmission. Common issue with the older model washer is not enough or old transmission fluid.. If you can give us a model number, we may be able to find better direction on how to do those things.
由 oldturkey03 完成的
Oldturkey03, I am new to the forum and could also use some help on this, can I just email you?
由 Robert Brunet 完成的
