跳转到主内容
加入维修社区 - 创建账户
Craftsman 品牌乘用割草机的维修信息与故障排除。
Engine WIll not crank
Craftsman riding mower engine will not crank. Installed new battery and still will not crank.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
4条评论
Is the mower turning over at all or is it just a dead mower?
由完成的
turning over backfires thru carb
由完成的
adjusted air gap valves set gap on coil
由完成的
after I changed my blades incorrectly the pgt9000 would not start with the switch. I can jump the solenoid and it will crank and run . I changed the switch and the solenoid , but still have to jump the solenoid. I think there is a relay that blows if the blades aren't on correctly, but I can't find it.
由完成的
添加一条评论
1个答案
最有帮助的答案
Are you getting any response when you turn the ignition? If not, it may be your starting solenoid or spark plug. Both are sold as replacement maintenance parts at most retailers who carry lawn and garden supplies.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Pamela 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 43
总计 2,300
