跳转到主内容
Model A1138 / 1440x960 screen resolution
85 个问题 查看全部
What could cause screen distortion?
My Powerbook screen will unpredictably be distorted to the point where it is unusable. Here's a video of it http://www.youtube.com/watch?v=hmkZFEtae...
The distortion does not show up on an external screen or screenshot, is not affected by moving the screen, but can be cleared with a whack on the bottom of the laptop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Wow, that wins the award for the most colorful screen malfunction of the day!
That's great that it doesn't show up on an external screen -- this means that your logic board is good, and that the problem is likely within the realm of the screen components. It doesn't seem that the lighting is flickering or going out (which would point to inverter/inverter cabling/screen), so I suspect the video cable, or the screen itself. The first thing I'd do is pop the topcase off and verify that the video connector is fully seated into the socket on the logic board...it could be something as simple as that. Next, you may need to open the screen casing in order to verify that the video cable isn't getting crimped somewhere, and to also verify there is a solid connection between the video cable and the back of the screen. If none of that does it, I'd replace the video cable, and if that still doesn't fix it, the screen itself may need to be replaced.
Good luck!
这个答案有帮助吗?
得分 4
5条评论:
完成的
Thanks!
完成的
+ nice to see you back
完成的
+ Ralph
完成的
I replaced the display cable and it has worked so far.
完成的
添加一条评论
添加你的答案
Riley Chapman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,288
