跳转到主内容
Released Spring 2015 RCA 7-in 8GB Adroid 4.2 Tablet
What do I do if the battery explodes?
After use, the device battery has puffed up like a bag of popcorn, and I am unsure if it can be repaired or will need to be replaced.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Take the battery out
完成的
添加一条评论
2个答案
已选择的解决方案
Exploding battery is a common problem associated with the device. If you notice bulging in the back of the device indicating the battery has expanded, or the battery has exploded entirely it is necessary to replace the battery for continued use. See Battery Replacement Guide for replacement instructions.
这个答案有帮助吗?
得分 2
添加一条评论
If its just the battery it can be replace with the mother board. My friend took out the battery an replaced it with a new mother board and battery it works just fine now
这个答案有帮助吗?
得分 0
1条评论:
Teishka Candelario why would you suggest to replace the motherboard? The device definitely needs a new battery but not sure why you think it would need a motherboard.
完成的
添加一条评论
添加你的答案
Kirby C 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,551
