跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Missing resistor near charging connector
Hello.
When I changed my battery on iPhone 5s it started to do some blue screen stuff. Then I bought another battery from ebay, and after that my iPhone is stuck at boot loop. I almost gave up on my phone, then I saw very tinny resistor missing near charging connector.
Image with marked resistor:
Could this be problem?
Anyone knows any data about this resistor and maybe where to get it?
Thanks a lot :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Simon Novak, sorry it is not a resistor. That is reference designator C23 which is a 56PF 16V capacitor in a 01005 package.
这个答案有帮助吗?
得分 1
7条评论:
Thanks mate. Now I just need to find it online. I know someone that can put it back on...
完成的
Hi oldturkey03! i have same problem C23 is slightly knoked off and it moving but it still there. the problem is that iphone not charging (fake charging) is that C23s fault?
完成的
@inspiraattori most likely not. The fake charging can be caused by a failed U2 IC.
完成的
Yesterdey I replaced that C23 and now it charging like a charm :)
完成的
@oldturkey03 And I have other iPhone 5s and same problem (two of those missing). In iPhone 5s can I replace (C23 56PF 5% 16V NP0-C0G 01005) with iPhone 4 (C23 56PF 5% 6.3V NP0-C0G 01005)? It is same but in iPhone 4 component is 6.3V and iPhone 16V..
完成的
显示更多的2条评论
添加一条评论
Will not be a big problem even if lost. Only additional capacitors
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simon Novak 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,000
