跳转到主内容
加入维修社区 - 创建账户
型号 A1502 / 2.6 GHz(睿频最高可达 3.1 GHz)或 2.8 GHz(睿频最高可达 3.3 GHz)双核 Intel Core i7 处理器,配备 4MB 共享三级缓存。
Changing normal trackpad to Force Touch Trackpad?
Hello, I would like to know if it was possible to change the trackpad on my 2014 MacBook to a Force Touch Trackpad.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
添加一条评论
4个答案
已选择的解决方案
You'll need to wait until the system is shipped and the IFIXIT crew get their hands on one. You'll need to wait to be sure.
From what the Apple presentation shows I don't think it would work. Remember, there is more than just fitting in, the logic board needs to support it.
这个答案有帮助吗?
得分 2
6条评论:
I own a Macbook Pro Model A1398 (15" Retina Display) and was wondering about the same issue with the Force Touch trackpad. I mean I would hope the logic board would´t have change that much. Let me know what you guys have found out.
由完成的
Sorry, it won't fit. the space it uses is deeper than your current trackpad.
由完成的
The reverse? Use an older trackpad in the newest model? That makes no sense!
The issue is the same across all of the older MacBook Pro Retina systems. The size of the trackpad is deeper with the Force Touch trackpad.
由完成的
i think it can be but we have to wait IFIXIT maybe they have good information for us
由完成的
is there a way I can replace my trackpad on my mid 2014 MacBook Pro to a force touch trackpad?
由完成的
显示更多的1条评论
添加一条评论
最有帮助的答案
The A1502 without force touch uses a ribbon cable and the A1502 with force touch uses a socket to connect the track pad so no you can not.
这个答案有帮助吗?
得分 4
添加一条评论
Hi, and if I have a 2015 A1502 with classic pad, can i change it with Touch Force ? the motherboard seems the same :s
这个答案有帮助吗?
得分 0
1条评论:
The 2015 A1502 doesn't have a mechanical touch pad, all of them have force touch trackpads. Unless the board inside is a late 2013-2014
由完成的
添加一条评论
Hello.. will be possible to use a 2014 normal track pad or a 2012 mac? And it’s not force touch. Just the older type.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jay Luchmun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 8,559
