跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy S5 Active SM-G870A 于 2014 年 6 月发布。此设备的维修过程较复杂,需要准备维修套件和热风枪。
USB Charging Port Cover/Flap replacement?
Just checking how to replace the S5 Active's USB port flap. The regular S5 looks pretty easy but the S5 Active doesn't have a screw close to the flap.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
Thank you! I've had the cover/flap on by Gorillia tape since i posted up here and hs worked pretty well. The S5 Active covers are ridiculously expensive compared to the regular S5 so I haven't taken it on yet but might soon.
这个答案有帮助吗?
得分 1
添加一条评论
ATT provides free replacement, I know that much
这个答案有帮助吗?
得分 0
添加一条评论
Did they send back to Samsung to fix or there in store? Plus locally the closest AT&T service center is an hour away.
这个答案有帮助吗?
得分 0
添加一条评论
Check out this thread Repair/Replace USB Charging Port
这个答案有帮助吗?
得分 0
添加一条评论
Don't know about the Active. I have an S5 Sport. My port cover flap broke right in the middle. The extension that forms the hinge / retainer stud is a tough but flexible material. It stretches. I grabbed it as close to the little opening as I could with a pair of needle-nose pliers, pulled it slowly, it stretched, I choked up, pulled some more, it stretched, I choked up, pulled some more and it popped right out. I had purchased a replacement cover online, about $10. I was able to press that into the hole using a pair of precision screwdrivers. The whole thing took about 5 minutes. I was afraid the little piece that forms the retaining stud would break off inside the phone. That did not happen to me. If it happens to you, you won't be any worse off than you were before.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
MattCFII 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 5,103
