跳转到主内容
加入维修社区 - 创建账户
Google 推出的第五款 Nexus 手机。该机于 2013 年 10 月 31 日正式发布,配备 4.95 英寸 1080p 显示屏、2.26 GHz Snapdragon 处理器并支持 LTE。搭载 Android 4.4.2 (KitKat) 系统。由 LG 制造。
Rear camera not detected
A few weeks ago the rear camera stopped working on my Nexus 5. I tried several resets (both soft and hard) and even flashing older system images, to no avail (ironically, after a hard reset and an image flash the camera app disappears).
I decided to buy a new camera module to see if that would fix it. Now, with that installed, I managed to get the camera app back up, but it says that there is no rear facing camera on the device. As a note, the front facing camera still works perfectly.
I've double checked the connections multiple times and the camera module is connected solidly.
Has anyone else encountered this issue before? And, is it possible I just got a bad camera module or do you think I would need to replace the whole logic board?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
I have the exact same problem. Only exception is when I installed a new camera I couldn't get the camera app back. However if I access the camera through hangouts, then the front facing one works.
这个答案有帮助吗?
得分 0
添加一条评论
That's exactly how mine works. No amount of hard-resets or flashing causes the camera app to come back. I only have access to the front camera.
这个答案有帮助吗?
得分 0
添加一条评论
Bonjour,
J’ai exactement le même problème.
Avez-vous trouvé une solution ?
Cordialement,
Bernard
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ashley McKay 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 20
总计 1,401
