跳转到主内容
加入维修社区 - 创建账户
这是一款支持 Wi-Fi 的无人机,配备了内置高清摄像头,可用于拍照和录像。型号:PF722000
Blinking green light why?
Had a sudden loss of power or signal with drone it fell and broke cross section. Can't connect wirelessly or via usb. Just getting blinking green light which usually means motors out.
Any way stripped it a little and found white motor power plug completely disconnected. Unsure if this occurred on impact or worked loose causing motor stall.
Great thinks I. An easy job. Puts connector back firmly in place and checks all gold antenna connectors are seated and in situ.
Puts it back together and its the same. Giving off no wifi signal to connect to for diagnostic tests on motors.
Any one any clues? Could mainboard be toast.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
16条评论
Is it normal to be unable to connect via wifi or pick up the drone via a pc to usb connection with the drone when a motor failure occurs. Someone must have experienced similar issues. I understand diagnostics tells you if a motor is not running correctly but I can't connect so unable to diagnose issue. It did come down on one motor strut which I assume then sent the energy into the cross section which fractured.
由完成的
i have the same problem, green LED light keeps blinking
由完成的
Hi I was told to disconnect all motors and see if that brings it back to life if it does then a motors broken. It didn't work for me.
Mine was a shorted mainboard. I sent it off for repair and after a reflash it came back to life, the fan was replaced and a motor and cross section replaced. Whole lot cost me £80 Gbp.
由完成的
Hi stu where did you send it for repair I have the same issue
由完成的
Southend on sea in Essex. Was given guys details by Parrot. Are you UK based dan.? I can't put his email on here because of spammers. Basically the guy charges £15 for diagnosis of the problem and that includes return postage in the UK. If your happy with him proproceeding he gives you a price and if your ok with that you paypal him money and he proceeds. Alot cheaper than buying a whole mainboard if its an individual component out on the board. Heres there website. Use contact us section. http://custemz.uk/
由完成的
显示更多的11条评论
添加一条评论
4个答案
最有帮助的答案
read on forum that i might be your camera, disconnected or damaged cameras will give the green light flash.
let us know if this helped
这个答案有帮助吗?
得分 1
3条评论:
thank you this worked :)
if you don't mind me asking where did you find your information for this?
由完成的
why would this be a problem my lens is broken camera is not but im getting green flashing light can anyone help ?
由完成的
hey david,,, so if my camera is damaged and disconnectng it wil also giv blinking green light, so then i have to buy another camera for it to fly? i cant jus disconnect it?? what else causes the blinking green???
由完成的
添加一条评论
This problem has happened to me so.i just took off the nose cone. Checked the GPS Tab to insure the Connection is tight. Made sure that the tab wasn't resting next to that tiny resistor. Put the battery on without the nose cone and it fired up correctly no more flashing lights. Took it Flying afterwards
这个答案有帮助吗?
得分 0
1条评论:
We have a Sky Tracker gps video drone . We have tried calibrating it and the lights won't quit flashing . We have tried everything . Any ideas ? . And is there suppose to be a little line that is white ( almost transparent ) suppose to be sticking out ? Hope someone can help .
由完成的
添加一条评论
This was the final correspondence between Parrot and myself regarding my parrot bebop that never flew-
Hello Parrot thank you for the excellent technical support !  I received your trouble shooting document and followed it.  I also did some of my own troubleshooting, which included measuring the charge voltage on both batteries. Unfortunately nothing worked (Power light button only flashes green- no wifi connection- no fans- no power off-no reset-nothing else). According to your trouble shooting document along with Bebop forums on the internet the final solution was to send the Bebop back to your factory for additional refurbishment. The Ebay seller already has it back in their possession and has sent out a replacement Bebop to me. Once again I really would like to thank you for the excellent support and I look forward to my first Bebop flight with great anticipation : )
这个答案有帮助吗?
得分 0
添加一条评论
same problem on my bebop after crash then flashing green ligth occur. i am lucky that i find this session so i know what yould i do.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
stu 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 31
总计 20,032
