跳转到主内容
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 个问题 查看全部
Recently, the CPU fan started running at full speed. What is wrong?
The CPU/Video fan runs slow at startup, and gets ridiculously fast and loud after a few minutes.
I disassembled the computer to remove 3~4 years of dust on the heat pipe fins, but the problem remains.
It is the nVidia logic board GPU that is running at 160 deg F. It has the CPU/GPU fan running at a full 3600 RPM. Is this in spec or am I going to need to try to re-seat the heat pipes to get a better thermal connection?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
did you replace the thermal paste on the cpu/gpu?
i had a few macbooks with heat problems, the paste was hard and almost useless - in other cases, there was way too much of that stuff on the chip's (original apple!).
replacing it is a must!!
这个答案有帮助吗?
得分 5
5条评论:
+ although nick recommended the thermal paste first, I'm gonna uptick ya. LMAO
完成的
no, he edited it in his answer after i wrote it - as always (check the history - but i think he will delete his post soon - also as always)
完成的
you are aware that everybody can see the "edited by" and of course the history of a posting.
完成的
@ Markus...I was being sarcastic. LOL
完成的
;-) and nick, it's not that "I" have a copyright on the stuff i'm writing. but it's lame to edit the stuff of an answer in the own answer - only to - yeah - only to what ? get a better reputation score? it's like the deleting stuff that you always do - i delete my answers if the worst case happens and mayer, majesty and answer at the same time - like a few minutes ago.
完成的
添加一条评论
Try downloading a demo of iStat menubar.
Then you will get a good look into the CPU processes and temperatures in your iMac.
heres the program
这个答案有帮助吗?
得分 1
2条评论:
If you'd given a link you'd have gotten an upvote.
完成的
i edited this with a link
完成的
添加一条评论
You could also try Activity Monitor, which is included with OS X.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jeff 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 10
总计 2,551
