GoPro Wifi not working
My GoPro says the wifi is turned on but my phone/laptop/ipad do not see it. Seems like maybe the antennae?
Did it stop working suddenly, or are you pairing it for the first time?
If the GoPro had heavy impact there could be internal damage, but I would try this first:
Update your Hero3 to the lastest firmware:
Next follow these instructions to pair your GoPro with your device: https://gopro.com/support/articles/gopro...
Section 1:
Wi-Fi Network Can't be Found in Phone/Tablet
If the camera's Wi-Fi network can't be found in the phone/tablet's wireless settings menu, follow these steps:
Turn off/on the phone/tablet's Wi-Fi.
Power off/on the camera.
Make sure the camera is in GoPro App or Phone/Tablet or mode and that you see a Wi-Fi icon in the bottom-right corner of the camera's screen.
Try to connect to the Wi-Fi network with the phone/tablet.
If the network is not present in the phone/tablet's list, try another phone/table if possible.
Redo the software update.
Section 2:
GoPro App Shows CONNECT YOUR CAMERA Message
If the GoPro App shows "CONNECT YOUR CAMERA", this means that your phone or tablet is not connected to the camera's network. Follow these instructions to resolve the issue.
这个答案有帮助吗?
My hero3 is powering off when trying to pair the WiFi for the first time. Any ideas?
My Hero3 White did come up on my wifi list. Then I updated it per above instructions...now nothing shows up. No way to go backwards?
Had the same issue.
After updating it worked like charm.
Go to https://gopro.com/en/us/support/product-... to update the firmware.
Then follow one of the Youtube videos like https://www.youtube.com/watch?v=La_9TyI5...
Updating the firmare FIRST worked for me ‘
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 43
总计 68,608
5条评论
my wifi on my gopro hero 4 blackwont turn on
由 Frank Taitague 完成的 分享
Tengo el mismo problema, Gopro me dijo que la envie a garantia, en mi pais no hay oficinas ni servicio tecnico de gopro. la gopro no enciende luz azul, no emite señal wifi wireless
由 tomasdasso 完成的 分享
tuviiste solucion?
由 maxteam 完成的 分享
Seems every time I use my GoProBlack after a period of time, I have to pair my GoPro again as the wifi won't connect. To pair again, go to your Bluetooth settings and "forget this Bluetooth device", yes, Bluetooth, not wifi. After this reset, you can pair the camera with the GoPro App. I've missed so many lovely opportunities having to go through this hassle every time. Worse when I've mounted the camera out of reach and have to start all over again and again and again. Miserable when I mount the camera on the truck as it seems to have a sensor that knows you have pulled into traffic and can't stop for a eleventh try. Never buy a GoPro again!!!
由 jeffgeorge 完成的 分享
I have a GoPro Hero 3 Silver Edition on my DJI F450 Quadrocopter.
I bought it as spares and rebuild it from 2 different faulty GoPros.
It is working flawlessly except:
-No sound in videos. Sometimes it makes a crispy distortion sound for 1 second.
-WiFi turns on (blue LED blinking, no broadcast)
I have 2 other faulty GoPros. One has a burnt SoC IC due to swapped polarisation at the USB port by the pre-owner. The other one just won 't turn on, maybe due to water damage or a crash.
My thought is to unsolder the WiFi IC from my working one with hot air and replace it with a one from the spare PCBs. Do you think it will fix the WiFi issue?
So how about the sound error? Do you think the fault is inside the SoC IC?
Your help is appreciated.
Best regards,
Tolga
由 Tolga 完成的 分享
