跳转到主内容
加入维修社区 - 创建账户
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
Are these the right SSD PCIe blades for iMac Late 2013?
Hi,
I need to be 100% sure that if the information it's correct. I want to place a PCIe SSD blade to my Imac but I would like to know if any of the below options works for my IMac, if you agree with the following information please let me know:
1) Apple SM0512F or SM0256F SSD PCIe blades are the same Samsung blades models MZ JPU512T/OA6 (512GB) and MZ JPU256T/OA6 (256GB) respectively.
2) Those blades are used and compatible with the following models:
  • MacBook Pro (Retina, 13-inch, Late 2013)
  • MacBook Pro (Retina, 13-inch, Mid 2014)
  • MacBook Pro (Retina, 15-inch, Late 2013)
  • MacBook Pro (Retina, 15-inch, Mid 2014)
  • MacBook Air (11-inch, Mid 2013)
  • MacBook Air (11-inch, Early 2014)
  • MacBook Air (13-inch, Mid 2013)
  • MacBook Air (13-inch, Early 2014)
  • iMac (21.5-inch, Late 2013)
  • iMac (27-inch, Late 2013)
  • iMac (Retina 5K, 27-inch, Late 2014)
  • Mac Pro (Late 2013)
  • Mac mini (Late 2014)
Am I right?
If yes, these blades would work for IMac 21,5" and 27" Late 2013 and 2014.
I just need to be sure before I buy some used pulled from a Mac lap-top
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 9
8条评论
Where are you getting the information that these blades will work?
完成的
Oh, that question is an old one ; I got that information after a deep research and from experts, indeed IFixit sells a PCIexpress blade for iMac late 2013 of 21.5" as well 27" but finally I decided to buy a Crucial SSD 550GB model MX200 and works beautifully, the OS boots in only 10 seconds and the speed was increased from 60 MB per second to 512MB
完成的
Armando, I researched this up and down. I'm tired of the "oh that's too hard to do, or you'll break you mac, or you'll void the warranty" etc etc :)
I am trying to figure out if I have the model with a 1TB HD installed already, can I put a new SSD drive into a PCIe slot by accessing behind the mainboard.
Did your machine already have an SSD or was it a standard HDD installed model, I got the impression that some seem to think that the standard models don't have the PCIe slot but I'm not sure I believe that.
Thanks for your posts so far!
Brian
完成的
Brian, where you able to find out if the PCIe slot is available even if is wasn't a fusion drive model?
完成的
gave up efforts to dig around inside. It isn't my machine and didn't want to hurt it trying
Ended up SSD to USB3 which might seem bad but it's a good 2nd tier solution
I've done ssd to USB2 on even older machines and that's a marked improvement.
Even thought the seeming difference in bus transfer speed might be a small impact
90% of the gain in SSD usage is from the access time.
Sure it's an externally attached boot device so you can ant to be careful about that but it is a desktop after all so should be possible to make that work
Also if you might want to spend more you could get a thunderbolt drive but I didn't think the cost is worth it.
So I'm happy enough with SSD to USB3 for boot and other USB external storage.
By the way... boot times are in the 10s range
Write is about 150-300
Read tunes are more reliably 350+
This is with an older model SanDisk SSD Plus 480gb....
完成的
显示更多的3条评论
添加一条评论
12个答案
已选择的解决方案
Sadly, you're between a rock and a hard place here. As the model you bought came with a HD Vs a SSD to start with. You may want to think about getting a replacement system which has the SSD and then transplanting your HD in to it Vs trying to open the system to add in the SSD. Then get another HD to put in your system and sell it to recoup some of what you spent.
While its possible to add the SSD, its a lot of work and and you have discovered not easy to identify the correct SSD to buy to put in. I should point out the SSD's also have firmware on them which also limits which system it will work in. So getting the correct looking SSD (even by vendor P/N) may still not work! We have the newer Mac Pro systems and we also tried to locate alternative SSD's for them, of the four we bought we only got one to work.
Review these two IFIXIT guides:
Note the number of steps needed to replace the HD 29 and 58 for the SSD. Are you up to this much work? Do you have the needed skills and tools?
OK, as to using an external SSD to marry with your internal HD: I would hold off that direction. Instead I would get an external dual drive unit and then use one of the bays in it to hold the SSD and marrying it with the mate HD so the external drive is setup as a fusion drive. While this will be more expensive it will offer more stability and speed than spitting across the internal HD and external SSD.
iMac Intel 21.5" EMC 2638 Hard Drive图片
指南
iMac Intel 21.5" EMC 2638 Hard Drive Replacement
难度:
中等
1 - 2 hours
iMac Intel 21.5" EMC 2638 Blade SSD图片
指南
iMac Intel 21.5" EMC 2638 Blade SSD Replacement
难度:
中等
1 - 3 hours
这个答案有帮助吗?
得分 3
添加一条评论
this is the old one
MacBook Pro 13" Retina Display Early 2013 SSD Replacement
and this i that you need:
MacBook Pro 13" and 15" Retina (Late 2013-Mid 2014) SSD
So that have to be compatible
If you have a 21,5" iMac and want upgrade your RAM: you need at 1,35V RAM 1,5V would`t work.
Replace or upgrade your solid-state drive.图片
产品
$59.99
这个答案有帮助吗?
得分 2
7条评论:
I already upgraded the RAM to 16GB but I am not sure if puting a PCIe SSD blade is worth to make only and exclusively to make a Fusion drive or can I use original HHD and the new SSD PCIe separately. Thanks for your answer!
完成的
I know it because I have opened the iMac and counted the pins, But it is much cheaper to build a large ssd a. The PCIE SSD for Apple is simply too expensive. and you can of course use the disks individually and how create a fusion drive and separate them, you can see at google
完成的
Yes Paul, I agree with you and I thank your advice, I also have seen they are extremely expensive, great that IFix have them, also I could buy an Apple used one pulled from a compatible MacBook but I'll wait until prices drop and look for an Thunderbolt/USB 3.0 connection external SSD. Thanks for your comment!
完成的
BTW Paul, My computers has only ne SATA III 6GB connector so I think it is not possible to make an internal fusion drive with adding an internal SSD plus the original 1TB HDD.
完成的
Armando you are correct your system has one SATA port (HD) and one PCIe port (SSD). There is one option here if you want to swap out your current HD drive to either a dual drive Western Digital Black2 or a hybrid drive: Seagate Laptop SSHD.
完成的
显示更多的2条评论
添加一条评论
This is my 21.5” late 2013 iMac’s logicboard. Which PCIe SSD blade I can buy (included used mac disks)
Thanks
这个答案有帮助吗?
得分 2
添加一条评论
Can someone help me? I've gotten a new iMac late 2013 21.5" i5 2.7 with 1tb hdd. I want to add a ssd on the pcie slot but can't find anything that's says "yes this is the part number you need".
I'm fine with the install, going to do the ram at the same time and only open it once. I just can't find any definitive answer as to which ssd module will be compatible.
Not wanting a fusion set up. Want apps and os on ssd and photo library on hdd.
这个答案有帮助吗?
得分 1
1条评论:
Apple has jumped a round a bit here on the 21'5" models, some systems don't have the SSD blade drive connector. In your case the Late 2013 does have the connector.
But, currently there is no third party options that have been tested unlike the older models as your system offers a 4 lane PCIe interface unlike the older systems. I would keep an eye on this web page: OWC - iMac 21.5" Late 2013 — Current. As to the upgrading this is not an easy upgrade! As you can damage the display if you are not careful and you'll need to take the entire logic bd out. You may want to think long and hard here before you do this. I strongly recommend going with an external Thunderbolt drive as being a better upgrade. Here is what I would go with: OWC ThunderBay 4 mini.
Review my answer above and the comments of the others. The cost of a real Apple SSD is quite expensive so that too needs to be figured in here.
完成的
添加一条评论
I just installed SSD blade from OWC to iMac 27" late 2013 . Only thing you need is screw to secure OWC drive in slot , stickers for re-glue LCD and few hours of time. Best regards , Milos / maczone.cz
这个答案有帮助吗?
得分 1
1条评论:
Hi Milos , it seems OWC finally are selling the PC express blades for our iMacs, whenI was interested they were planing to produce them but I couldn't get any one, it was only their project. Finally I installed a 1 Tb Crucial SSD MX 200 and work beatifully but thanks for telling me that the proper blades are available at OWC maybe I will but one.
完成的
添加一条评论
From my resent research, you can also put a PCIE SSD drive in the late imac 2013 and run them together. I've seen other 2013 imac's done this way
这个答案有帮助吗?
得分 1
1条评论:
aeuja64 - Only if your system has the SSD blade slot. Some of the 21.5" don't have the parts mounted on the logic board!
完成的
添加一条评论
i just found a PCIe SSD that works with the 21.5" 2.9GHz i5(the model that has the PCIe slot). i am getting about 650mb write and 710mb read; it is awesome. i was already getting great speed with the samsung SSD i have in the main SATA3 port but the PCIe is much faster. i am working now on identifying which SSD models are compatibles.
这个答案有帮助吗?
得分 1
1条评论:
Is the Gen 4 (MZ-JPV ...) version of the SSD blades are suitable?
完成的
添加一条评论
I have a late-2013 27" iMac with 1TB HD. It also has PCIe slot for SSD, in which I installed a 256GB Samsung SSUBX/SM951/JPV256 655-1858 that I bought on eBay. I merged the two into a Fusion drive and they work fine together.
这个答案有帮助吗?
得分 1
2条评论:
I also have a late-2013 27" iMac. I have not opened it, and would like to know if I can place a NVME SSD in it! So you're saying you did it; so is the NVME socket definitely there? I heard it depends whether you had Fusion or not... I just have the 1TB HD, apparently just like yours..?
Can it be any NVME SSD or must it be a special Apple kind?
完成的
My iMac 27 Late 2013 has empty PCIe slot and should support NVME. Here is complete info about Apple proprietary.
https://beetstech.com/blog/apple-proprie...
Issues of cheap upgrade are:
1) Need of 12+16 adaptor - quite cheap (eBay)
2) iMac 27 Late 2013 has only PCIe 2.0 support (Generation 3). So a lot of newer SSDs with PCIe 3.0. will not be compatible, even original blade SSD from MacBooks 2015 (Generation 4).
So finding of SSD with NVME and compatible with PCIe 2.0 is quite challenging. And I'm still searching.
完成的
添加一条评论
As far as I have read (could be wrong though) the PCIe slot is only present if the iMac was ordered with a Fusion Drive. Can anyone confirm this?
It is then easy to setup your own Fusion Drive combining any PCIe blade with a normal drive. You can not make a Fusion Drive from 2 SSDs though. No support for that.
Also I am not sure if TRIM support is possible with 3rd party drives.
If the PCIe slot in the 2013 iMac is the same as for Late-2013 MacBook Pros then you can use any cheaper PCIe NVMe blade SSD. I got an adapter from Sintech ($9) so I can use any PCIe M-Slot blade SSD.
The NVMe support was introduced with MacOS High Sierra. I am using a 1TB Samsung SM961 in a 2015 MacBook Pro 15" that achieves blazing speed 1400/1900 MB/s. And I got it on Ebay for $530. Has anyone tested this on the iMac?
这个答案有帮助吗?
得分 1
2条评论:
All 'Thin Series' 27" iMac's have a blade SSD interface. Different year'ed models have different blade SSD's so you do need to be careful which model you have and what is the correct blade SSD for it. The 21.5" 'Thin Series' are the ones that maybe missing the blade SSD interface! A SATA HD only system might not have the needed parts populated on the logic board. A Fusion Drive'd system will as well as a blade SSD only model, depending the year'ed model the current 21.5" models have it in all of the configurations.
No you can't use two SSD's configured as a Fusion Drive. You could RAID them but the issue you face is the I/O has to be the same which clearly won't be here.
Most 2.5" SATA SSD's support TRIM services. The kicker is the real cheap no onboard RAM SSD's won't.
Review the image I posted below for the rest.
完成的
My late-2013 iMac 27" did NOT originally come with a Fusion Drive. It just had a standard HDD. It also had the PCIe slot, however. As noted, I added an OEM (Samsung) blade SSD in the PCIe slot and then merged it with a 1 TB SSD to make a 1.25 TB Fusion Drive. TRIM is enabled.
完成的
添加一条评论
NVMe is a new interface think how PATA was displaced by SATA. Here we are displacing AHCI/SATA with NVMe/PCIe it's a very different interface. So you can't use a PCIe SSD in a SATA based system.
Depending on the MacBook Pro or iMac Series it will have either an AHCI or PCIe interface. Here's a better way to understand the complexities:
The other issue with PCIe is the number of lanes. Most of the PCIe/NVMe are 2 Lane (x2) and most of the Mac systems support 4 Lane (x4).
The other factor here is the Apple to M.2 adapters being sold. Many are not very good! We tested 4 different ones and most dropped data blocks (CRC error) so over time you'll likely wear out the SSD sooner and could end up with data loss. And the speed won't be as good as the real Apple drive our even one of the SSD's designed to work in an Apple system (OWC & Transcend). I don't recommend using the adapter, I do recommend using OWC & Transcend's SSD's!
As far as using something other than the real Apple drive I don't know of anyone trying. Even OWC and Transcend limit their support to the SATA drives in the iMac's as it's such a big job to get to the blade SSD.
这个答案有帮助吗?
得分 1
添加一条评论
This page is a GREAT resource for figuring out Apple PCIe/SSD blades:
I was able to get a 1TB PCIe SSD from a MacBook Pro (2013) and put it in my 27” iMac (2013) - everything works great. Although have an assortment of various Apple screws around for holding the blade in place, it is spring loaded and wants to to pop-up!
Lastly, if you put in both a PCIe blade ANDa SATA SSD (using the OWC in-line SATA thermal sensor) and format it as a CoreStorage Fusion Drive in High Sierra when you go to upgrade to Mojave it will balk and say you have an “Unsupported CoreStorage Configuration”. The trick is to FORMAT the Fusion Drive as APFS with Disk Utility when booted with a bootable Mojave USB. Yes this wipes out the data, make a backup! The Mojave installer though will now happily install on your PCIe Blade+SSD Fusion Drive
这个答案有帮助吗?
得分 1
添加一条评论
I Have the same basic question but with a 27" late 2013. Some comments state that the PCIe slot only exists if it was installed at the time of purchase but I am not sure I believe that.
I would like to add an SSD to the PCI express slot as my main system drive and keep the internal 1TB drive for additional storage (I already have 6 external drives connected by everything from Thunderbolt-Firewire converter and eSATA to USB 3.0 so am just not interested in adding anything but an SSD to increase system performance (preferably keeping the existing internal 1TB drive!) - Yes I have the necessary tools and am able to do the install - carefully! :)
这个答案有帮助吗?
得分 0
9条评论:
@Brian - The 27" is different than the 21.5" model being talked about here.
In your case the SSD blade drive connector is present. But, currently there is no third party options that have been tested unlike the older models as your system offers a 4 lane PCIe interface unlike the older systems. I would keep an eye on this web page: OWC - iMac 27" Late 2013 — Current. As to the upgrading this is not an easy upgrade! As you can damage the display if you are not careful and you'll need to take the entire logic bd out. You may want to think long and hard here before you do this. I strongly recommend going with an external Thunderbolt drive as being a better upgrade. Here is what I would go with: OWC ThunderBay 4 mini.
完成的
Thanks Dan, I appreciate the thorough answers you've given before. Unfortunately the Thunderbolt enclosure+SSD is way too expensive for what I'm looking for. In my case the hassle of opening the machine up would be worth it to be able to put in a 500GB SSD(~$150) to boot from and use as intermediate storage during editing retaining the internal drive, I don't need huge fast external data storage, all of that is fine as USB3.0 (still way cheaper than Thunderbolt) and just as functional for most of my usage.
Speed/Size/Cost: Pick Two :)
I'm going to just replace the HD with the SSD, and move the drive external to USB3 enclosure :/
I will say this, the SSD upgrade is the single best thing anyone could do to improve the performance. If you haven't done it yet to an aging machine you owe it to yourself - it will make even the oldest machine feel relatively snappy! :D
完成的
The problem you face here is the systems storage space will be less with a SSD only solution if you are forced to look at the cost factor. A 1 TB SATA SSD is still on the expensive side (~$320 US) that is if you are looking at an Apples to Apples comparison swapping out your HD from a size perspective. Going with a 500 GB drive (~$160 US) while doable will lessen your storage as you are giving up your 1 TB HD!
Again, there is no 3rd party PCIe blade drive offerings so you will need to go with a real Apple SSD which will cost you! 512 GB (~$650 US) 1 TB (~$1000 US).
完成的
So the external Thunderbolt drive (ThunderBay) I think looks better here as a 1 TB SSD will set you back $820 US or if you want something cheaper a 500 GB SSD setup is only $620 US.
Here's one other option which is cheaper than the ThunderBay RAID case: Elite Pro Dual enclosure. Here you can add in your own 2.5" SSD's. The case alone only costs $240 US. Just keep in mind this is a 2 drive case Vs the 4 drive case so your future expansion will be limited. Still a great buy! I have one for my home system holding my old HD disks.
So if you go with a 500 GB Samsung 850 EVO $160 plus the case $240 for a total of $400 I think you'll still end up with a better deal!
Don't just look at the costs of the drive alone here also think about the risks in opening up the system and the hidden costs if you mess up.
完成的
I think we just have different perspectives on what value is here. Our goal is maximum performance(#2) at minimal cost(#1), size of the upgrade is negotiable.
An enclosure itself that costs 240$ is just way out of line with what we want to afford.
So looking at it this way a 500GB SSD running at full SATA installed internally will be the best value given comfort with the upgrade process (having done similar upgrade on another iMac and various othe repairs, and the fact that my time is not as much a factor here.)
Then moving the 1TB to an external USB3 docking station means I don't lose any total storage but also helps keep the total upgrade cost to ~200
Also, since ideally I would try to boot from the SSD, minimizing the risk of data/work loss from an inadvertent disconnection would also is worth putting the drive internally.
With all of the caveats for such a statement: I wish apple would get back to a modicum of their beginnings and allow things to be upgraded more easily.
Hope this helps others too!
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Armando 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 23
过去 30 天: 96
总计 45,785
