跳转到主内容
加入维修社区 - 创建账户
MacBook Pro 13" Retina Display Early 2013 SSD Replacement
你所需要的
  1. MacBook Pro 13" Retina Display Early 2013 SSD Replacement, Lower Case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 2 中的图像 1,1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 3 中的图像 1,3 MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 3 中的图像 2,3 MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 3 中的图像 3,3
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2013 SSD Replacement, Battery Connector: 步骤 4 中的图像 1,1
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 5 中的图像 1,1
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 6 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 7 中的图像 1,1
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 8 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 8 中的图像 2,2
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Early 2013 SSD Replacement, Battery Contact Board: 步骤 9 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 SSD Replacement, Battery Contact Board: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Early 2013 SSD Replacement, SSD Assembly: 步骤 10 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 SSD Replacement, SSD Assembly: 步骤 10 中的图像 2,2
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
  11. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 11 中的图像 1,3 MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 11 中的图像 2,3 MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 11 中的图像 3,3
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  12. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 12 中的图像 1,1
    • Remove the SSD assembly from the upper case.
  13. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 13 中的图像 1,1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the SSD tray.
  14. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 14 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 14 中的图像 2,2
    • Insert the edge of plastic opening tool between the SSD and the SSD tray, opposite to the socket side of SSD tray.
    • Pry the side of the SSD opposite the SSD tray socket out of the SSD tray.
    • Only lift the SSD up far enough to grab the sides of it with your fingers. Lifting it any more may damage the card or socket.
  15. MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 15 中的图像 1,2 MacBook Pro 13" Retina Display Early 2013 SSD Replacement: 步骤 15 中的图像 2,2
    • Carefully pull the SSD straight out of its socket on the SSD tray.
  16. MacBook Pro 13" Retina Display Early 2013 SSD Replacement, SSD: 步骤 16 中的图像 1,1
    • SSD remains.
结论
55等其他人完成本指南。
Sam Goldheart
于10/18/12注册
475,494 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,913篇指南
8指南评论
Excelente, muchas gracias
Ruben Morales - 回复
Ok, now that I replaced my SSD - how do I recover my OS?
Andy Stevko - 回复
You can boot your mac to the recovery pressing command + R while you turn on your mac, configure your wifi and then create the partition in the ssd using disk utility, then you can clos disk utility and proceed to the instalation of the OS, the installation will be downloaded from the apple servers so it will depend of your internet speed how long will it take.
Ivan Roque -
Sieht so aus, als würde da eine ganz normale 2,5”-SSD reinpassen, wenn man den Einschub weglässt. Kann man das Kabel am MBP entfernen und ohne den Einschub benutzen?
Familienfreundlicher_Nutzer - 回复
Geht leider nicht. Die neue NVMe m.2 SSD muss eine Übergangslösung haben. Leicht zu finden beim Internett. Das Übergang ist ein kleines Zeug das Mann braucht der Länge und Datei - Brikett zur passen.
Adrian Swift -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 59
过去 30 天: 269
总计 147,387
