跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Earpiece with no audio... Board problem
Hi there
I had just got my iPhone 5 16gb as a gift from USA
BUT unfortunately it got no service warranty
Few days after I had an error that earpiece stop working
I asked for help from some local service center specialized in Apple products
He told me that isn't earpiece or it's cable problem
It is audio ic problem which he considered it unrepairable
Did he says right ??
Is iPhone board could sold alone as spare part ?
Would I lose my data if I did change the board ??
Thanks a lot
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Hello,
First off, does the front camera and/or proximity sensor work? those are also on the same cable at the ear piece. To test the proximity sensor would be to make a call and put your hand over the spot right above the ear piece. If the screen goes black then it works if it doesnt then there is something wrong with that cable. Another thing ive seen if is the phone thinks there are head phones plugged in it wont use the ear piece. That can be checked buy turning the volume up and down. When the pop up for the volume level comes itll say if head phones are plugged in or not. If it does then you would try cleaning the headphone jack, or you might have to replace that cable instead. The ear piece or headphone jack cable are very easy to do.
Here is the guide to replace the earpiece...
iPhone 5 耳机扬声器替换
Here is the guide to replace the headphone jack
iPhone 5 尾插更换
To answer you other questions, yes you could replace the board, but that is close to the same cost as another phone. You would lose all your data as well unless you did icloud for a backup and restore. I would suggest checking everything else out first before considering replacing the board.
iPhone 5 耳机扬声器图片
指南
iPhone 5 耳机扬声器替换
难度:
中等
iPhone 5 尾插更换图片
指南
iPhone 5 尾插更换
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 1
添加一条评论
Thank you for your reply
Proximity sensor check OK
front camera check OK
headphone jack check OK
The service center I went to told me that he tried to replace both the earpiece and the flat cable but the error remains so he figured out it is on board problem
Would you recommend to try again myself using the above guides ??
这个答案有帮助吗?
得分 0
1条评论:
I do not think it would hurt to atleast try replacing them to make sure. the parts are rather inexpensive. its worth a shot, if the pro still shows that the ear piece doesnt work then something on the board would have to be damaged.
完成的
添加一条评论
添加你的答案
Hussam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 190
