跳转到主内容
加入维修社区 - 创建账户
Sony Ericsson Xperia Arc S 是一款搭载 Android 2.3.4 系统的手机,配备 1.4 GHz Snapdragon CPU 和 14.4Mbit/s HSDPA 数据传输速度。
How to increase the ram speed
how can i increase the ram speed and increasing internal memory
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
2个答案
Go to settings and check running applications. Check if any unwanted application is taking up RAM space. manually force close it. Your device should work fine.
You can also ROOT your device, which means getting an Admin access to your device core file system. This allows you to remove any apps that you think is taking up RAM spaces.
!! ROOT is risky, since it is getting you an admin access to core files, any alteration or modification can brick your device." If that happens you will loose the warranty. (If you are having any)!!
这个答案有帮助吗?
得分 0
2条评论:
Is there any way to make the applications not starting up again when rebooting the phone?
完成的
This can be done on settings i am sure of it. Go to applications and have a look.
完成的
添加一条评论
I was Like You root your phone and install link2sd remove original system apps or
install grinify and freeze apps this is better if you didnt root
apps like facebook will take 80-90 mb ram!!!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
madhavan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,843
