跳转到主内容
加入维修社区 - 创建账户
Acer Iconia Tab B1-A71 是 Acer Iconia Tab B1 系列的首款平板电脑,于 2013 年 1 月发布。
How to replace charging port?
Im attempting a charging port replacement on the tablet, i've got the old charging port off without any issues however I can't get the mounting holes free from solder to fit the new charging port in.
Could anyone advise on what I could try, tried solder wick but doesn't help much as I can't get enough heat into the solder between the holes
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Position the new port with its feet in place, then heat the area (I used a heat gun carefully) while applying a little bit of pressure with a pair of tweezers.
The solder (or whatever it is) will soften with the heat and the port will sink in. Remember to remove the yellow tape from the topside first!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
EvansITLtd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 2,315
