跳转到主内容
加入维修社区 - 创建账户
Acer Aspire V5 的维修指南和故障排除,这是宏碁(Acer)推出的一系列搭载 Windows 操作系统的笔记本电脑。
Screen Wont Turn on help please
When i turn on my laptop the light of the keypad turns on but my screen is all black? Need help please.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
5条评论
I have the same problem now. I know it's alive but no screen. I have my QuickBooks running and hate to force it turn off.
完成的
My screen won't turn on , but lights on the keypads work?
完成的
The light on the on/off button turns on for a bit but the screen and the rest of the camera don't react at all when I try to turn it on? Surely if the batteries were dead the light on the button wouldn't turn on?
完成的
Is Completely Black , Looks Like Internal Screen Damage
完成的
Thanx ifixit your information is very productive. ..I just fixed the problem with my acer v5..thanx again
完成的
添加一条评论
2个答案
最有帮助的答案
Dear All,
* Press Fn+F5 or Fn+F6 simultaneously while notebook is turn on
* if display switching not works just connect your laptop to external display and re-start (press and hold the power key until power LED goes off. after couple of seconds press power key again) and check any visuals on external display
* if you can see any visuals on External display, you should check the internal display and Flex cable and connector as well
  • Open the cover of RAM slots and remove RAMs safely, clean the RAM interfaces, reinstall RANs safely and try to boot normally
* onc of above step not works for you, its time for advanced level repair to check the GPU output and and CPU clocks and Bus (Board level repair)
这个答案有帮助吗?
得分 2
1条评论:
Thanx ifixit...Your information is very productive.. With your help i just fixed the problem with my acer v5..thanx again
完成的
添加一条评论
Hi friend,
Kindly reset ur bios..otherwise properly fix RAM.
METHOD 1:
Step1: turnoff ur laptop
Step2:remove ur battery
Step3:hold on power button 30sec
Step4:after directly connect the charger trun on ur laptop its working .after connect battery.
METHOD 2:
First u identify ur RAM part of the ur laptop.
Just remove ur ram and clean tha pins smoothly.
After re insert the RAM check it ..working or not.
If u any doubt text me my number:+919524629460 whatsapp
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 24
总计 12,670
