跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Microphone quiet/muffled when using front-facing video
Hi All! What does it mean when the microphone works fine when using the back video camera, but when you switch to the front camera the microphone input is quiet and muffled?
If you Google the issue it's apparent that lots of people have experienced this, but there doesn't seem to be a clear solution.
Thanks!
John
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
Hi guys,
I just faced with this problem today morning. The customer is a girl, with iPhone 8 (black), no scratch, perfect condition. Not that dropping kind of customer :)
Opened the phone, perfect, no liquid, no missing shields, no mixed screws, I think this never been opened before.
I did not even try to clean the mesh because it was clean already, just replaced the frontcam unit and baaam... working fine.
I never will understand this, the camera was in perfect condition just like the phone, reportedly was not dropped, so the mic just stopped working, weird.
完成的
Go to settings/camera and make sure record stereo sound is on.
完成的
添加一条评论
5个答案
已选择的解决方案
IMO it means the front mic part of the front camera flex cable is not *recording* sounds like it should. It could be that A/ the mesh covering the ear speaker and front mic is clogged, or B/ the cable is improperly seated, or C/ the mic or cable carrying it is damaged.
I'd start with A/, pierce the mesh of the ear speaker with a fine needles ~3 times in the middle of the mesh. Don't let it in more than ~1mm to avoid disturbing anything in there. Then test the mic.
B/ If no improvement, I'd use this guide until step 11 to disconnect then reseat the front camera cable. This may help, although not very likely.
C/ Change the front camera flex cable following the guide here above all the way to the end.
Note: if issue is a clogged mesh, it can be changed using that same guide here above to remove the front cam flat cable (like in option C), after which push the mesh in, from the outside towards the inside of the screen using a flat plastic tool. Get a replacement mesh from eBay or just peel off the top layer and put the rest back in. It's a bit of a pain to replace that mesh and there is always that inherent risk to every repair to damage the phone or screen.
iPhone 5 Front Camera and Sensor Cable图片
产品
这个答案有帮助吗?
得分 2
4条评论:
It's a bit detailed in case someone with less experience reads it and wants to follow the troubleshoot.
完成的
Thanks Rany, I appreciate it! I was posting for a friend, so I'll let him know the info and let you know how it goes.
完成的
Welcome! Never had this exact case before, so I'm guessing.. but that's where I'd look. Then if it doesn't solve it, would check the sound circuit on the board. But "muffled" pointed me towards a clogged mesh.
完成的
In my case, i disabled the “Record Stereo Sound” in Setting > Camera. Guess theres some bugs still in ios14
完成的
添加一条评论
最有帮助的答案
Looks like noise cancellation is "on" in your settings.
Go to settings>General>Accessibility. Right at the bottom is Noise Cancelation and my guess is that it's "on". Turn it "off" and Bingo, you'll be hearing sound on recordings again.
这个答案有帮助吗?
得分 3
2条评论:
UGH. Didn't work. It was "on" and I toggled it off, but still nothing. Can't figure it out yet.
完成的
same have this issue and nothing can be done
完成的
添加一条评论
Try this
Settings > Camera> turn off Record Stereo Sound
The muffledness went away for me
这个答案有帮助吗?
得分 1
1条评论:
worked for me thank youu
完成的
添加一条评论
https://www.amazon.com/gp/product/B07FFL...
Update (01/16/2019)
try this one. They claim this works.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same issue and thought it was the phone. Downloaded a third party camera app for better quality video and low and behold, it fixed the front mic issue. if i use the iPhone camera app its muffled. if i use the other app it works fine. so weird….
这个答案有帮助吗?
得分 0
1条评论:
I’m having the same issue, on Snapchat it records fine, but on the iphone “camera” front facing the sound goes in and out all muffled, I been testing it and seems like it’s using all 3 mics. But it isn’t clear or loud. It’s muffled and a lot of back static
完成的
添加一条评论
添加你的答案
rdklinc 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 14
过去 30 天: 49
总计 145,350
