跳转到主内容
加入维修社区 - 创建账户
Google 推出的第五款 Nexus 手机。该机于 2013 年 10 月 31 日正式发布,配备 4.95 英寸 1080p 显示屏、2.26 GHz Snapdragon 处理器并支持 LTE。搭载 Android 4.4.2 (KitKat) 系统。由 LG 制造。
Screen moving up and down randomly...shaking?
Hi I've had a nexus 5 device for almost an year...no issues..then a few days ago my screen started shifting up and down at will...I might have dropped it but if at all it was no more than 2..3 feet..this happens on any app..even home screen...like the screen gets wrapped around and the top part shifts up and comes back up from below...js keeps shaking...i can type perfectly if only i can click at the right place...neither the glass nor the image appears broken...stock software...help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 27
13条评论
I have the same issue it even happen in recovery mode too, definitely hardware issue
由完成的 分享
Did you check: https://www.youtube.com/watch?v=4pks4idq...
Looks like flex cable issue. I haven't tried it yet.
由完成的 分享
How can I fix it
由完成的 分享
why was my screen goig up and down a few minutes ago. What is going on. Fixit.
由完成的 分享
I purchased Nexus 5 LG from Amazon in 2014. Since last week, the screen has started flickering and shaking. I believe I made a mistake. I got excited after experiencing Nexus 4 Samsung. Google should have continued with Samsung, but not LG. Any help is welcome. Cheers. (N. L. Vijaykumar, Brazil)
由完成的 分享
显示更多的8条评论
添加一条评论
9个答案
最有帮助的答案
I fixed this problem by replacing the daughter board(Check step 8 on the ifixit article: Nexus 5 teardown) that contains Micro-USB port, Microphone, Notification LED, etc. Nexus 5 definitely has a major hardware flaw.
这个答案有帮助吗?
得分 2
添加一条评论
I faced the same problem on my Nexus 5 recently (after more than 2 years of usage). I was able to fix this problem by opening the back panel and pressing the flex cable (which might have gone loose) on connection areas.
In some cases the flex cable might have got damaged resulting in this issue. If that's the case with your phone (i.e. if even after the above procedure, the flickering persists), you can try replacing the Flex Cable. Check "https://www.youtube.com/watch?v=4pks4idq... for flex cable replacement.
这个答案有帮助吗?
得分 1
添加一条评论
Old thread but for anyone in the future asking this, I had the same problem and replaced the charging port. There's a good YouTube tutorial here and I found the part on Newegg here. I bought from that seller and had no issues. The replacement itself is pretty easy and it seemed to fix the problem.
这个答案有帮助吗?
得分 1
添加一条评论
hi everyone had the same issue few weeks back. i browsed regarding this problem. most of them said it was solved with changing the flex cable. i was then in vizag. showed it in lg service centre. they said we have to change the display. went to another shop he to said the same. i was not convinced. later i showed to in hyderabad at lg service centre again. i was ready to change the display. i just told him what i read in internet. to my shock he just changed the flex cable and issue was resolved. i just felt both guys in vizag wanted to make money. felt it is my responsibility to share this with u all. CHANGE THE FLEX CABLE.
这个答案有帮助吗?
得分 1
2条评论:
Sir what was the coast of changing it in lg centre
由完成的 分享
What is the cost of the flex cable
由完成的 分享
添加一条评论
i had the same probleme with my phone and i do this
https://www.youtube.com/watch?v=Af5DvIZw...
it work for screen too, it's the same cable.
i even try to change the daughter board but this look like a motherboard connecteur problem.
这个答案有帮助吗?
得分 0
2条评论:
Wait.. This is a permanent fix for the screen shaking\flickerng? Please respond because I need a permanent fix.
由完成的 分享
I have this problem of the screen moving up & down on all the programs I go into also.
由完成的 分享
添加一条评论
Replace the PCB board that contains the Micro-USB port (the one at the bottom).
Search for the following.
LG Nexus 5 USB port flex cable complete assembly.
Make sure you get a complete assemble (which includes the black plastic) otherwise its a tough job transferring the double sided tape.
这个答案有帮助吗?
得分 0
添加一条评论
I found a way to enhance connection of the flex cable: solder flux pen (no-clean), brushed on the connector, it works fine.
这个答案有帮助吗?
得分 0
添加一条评论
I experienced this on my iPhone just 1 hour ago, the problem only exists when power cable is connected and charging.
If disconnected from powersource, everything is smooth again.
The comment of Prashanth above is correct, something related to USB charging port. Maybe the smartphone was presssed hard on your pocket or was dropped which caused the problem.
这个答案有帮助吗?
得分 0
添加一条评论
my phone was scrolling up and down by itself.How do I stop it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
dev 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 31
总计 63,755
