跳转到主内容
How can I fix broken camera cable
While I am trying to remove the optical drive from my MBP with following the instructions of the iFixit, I could not remove the Camera cable socket and I broke off the cable from the socket. You can see the current situation of the cable and socket from the pictures I uploaded:
http://imageshack.com/a/img537/6886/ZRZd...
http://imageshack.com/a/img661/914/sfzmP...
For checking my system after this accident, I run my laptop and as I expected camera did not work. But everything except camera was working well.
So what's the way of fix this problem?
By the way, I just realized that actually I was able to remove the Optical Drive without removing that lovely socket!..
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Hello Yusuf,
Did you find a way to solve your problem?
Regards
完成的
Nope, not yet because of my unusual busy period i could not focus on this problem...
Also I am kind of hesitating about fixing this tiny problem with a huge technical solution as @Dan mentioned above.
I don't want to take the display off and its almost whole components, at least i think i am not able to make it possible in this way... If there is no other option, i guess i will have to go to some service/technician in a time.
完成的
添加一条评论
3个答案
已选择的解决方案
Well you're lucky here! you only pulled off the cable connector and did not damage the logic board connector (you'll need to carefully remove the remaining cable connector piece) while not the best picture look at this: Removed iSight cable connector. Thats the good news! Now the bad ;-{
To replace the cable you'll need to take the display off and then dissemble it. This is a very big job! And you do need to be more careful. Instead of going that deep you could replace the full lid assembly while more expensive it will be a lot easier! Here is the steps to pulling off the display assembly: MacBook Pro 13" Unibody Early 2011 Display Replacement.
You'll need to refer to this guide to give you an idea how to disassemble the display the rest of the way: MacBook Pro 13" Unibody Mid 2009 LCD Replacement Jump to Step 15, so you can get the cable connection on the displays logic board. The next issue is finding the cable which will be difficult.
MacBook Pro 13" Unibody Mid 2009 LCD图片
指南
难度:
非常困难
1 - 2 hours
MacBook Pro 13" Unibody Early 2011 显示屏图片
指南
MacBook Pro 13“Unibody 2011早期显示屏更换
难度:
困难
1 hour
这个答案有帮助吗?
得分 4
2条评论:
Hey Dan,
Thank you for your answer.
However, I'm a little confused about the part when you say "remove the remaining cable connector piece".
The photo in the link you've attached was referred to as the "Trackpad Cable" in step 10 of another ifixit page ( MacBook Pro 13" Unibody 2012末主板更换 ).
So i'm wondering if its the right cable, and whether it would be okay not removing that end of the cable.
Thanks
完成的
As I stated the image is the best I can find that shows the cable disconnected. Look at the top right corner in the image the two round cables the lower one is the video connector unplugged from its socket.
完成的
添加一条评论
hi I have the same problem and I need your help. My solution is to buy the cable and solder the wires one by one. It is much easier to disassemble the entire screen. the only problem is that the original cable has 6 colors (one for each cable) and cable replacement only 3 colors. in tonces I need to know the exact pinout to weld properly. you can help?
这个答案有帮助吗?
得分 0
3条评论:
Then you got the wrong part. Here's the correct cable: MacBook Pro 13" iSight Cable - Apple P/N: 821-0867-A
完成的
This cable is for MacBook Pro 13" early 2011?
完成的
@mimonton - How about creating your own question with your systems info as the is the correct part for the OP's system. Yours maybe different or you damaged a different cable. Take a good set of picture's to add to your new question. The more info the easier I can help you.
完成的
添加一条评论
Or you could just buy an external webcam and deal with that until your ready for an upgrade.
这个答案有帮助吗?
得分 -1
1条评论:
Sorry, the way macs work won't allow that as the displays camera has a thermal sensor which is now disconnected will force SMC into CPU safe mode causing the fan to race and the CPU to run at a slower clock rate.
完成的
添加一条评论
添加你的答案
Yusuf 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 81
总计 28,396
