I have a 5E code on my microvave
I have a 5E code on my oven it will not work it has power the inside light goes on bu nothing works
Keyboard error code. Unplug it for 30 minutes to allow it to reset then try plugging it back in.
这个答案有帮助吗?
It is a temporary fix.... its just that you have to keep doing it again. I'd like to get to the root of the problem...to know what is the cause.
Most likely in the keypad or perhaps the control board.
What is the model number of the oven?
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 28
总计 4,441
2条评论
sometimes it works. Most times it says set date/time then quits .
Other times it goes to an "SE" message & stops & freezes!
由 Brian Northcott 完成的
It is a model # Kenmore 401.85042010 Ser # 143MM01551
