跳转到主内容
Repair and disassembly guides for Kenmore Microwaves.
I have a 5E code on my microvave
I have a 5E code on my oven it will not work it has power the inside light goes on bu nothing works
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
sometimes it works. Most times it says set date/time then quits .
Other times it goes to an "SE" message & stops & freezes!
完成的
It is a model # Kenmore 401.85042010 Ser # 143MM01551
完成的
添加一条评论
1个答案
已选择的解决方案
Keyboard error code. Unplug it for 30 minutes to allow it to reset then try plugging it back in.
这个答案有帮助吗?
得分 2
2条评论:
It is a temporary fix.... its just that you have to keep doing it again. I'd like to get to the root of the problem...to know what is the cause.
完成的
@banjosqueezebox
Most likely in the keypad or perhaps the control board.
What is the model number of the oven?
完成的
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 4,883
