跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 个问题 查看全部
Resistor values near battery connector
Does anyone know the value of the resistor (capacitor? I've seen it labeled as both but neither post had values) circled in the picture. Caught it with a fingernail and now the battery charging indicator won't update. I'm reasonably good at smd soldering - just need to order the right part!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I have same problem with my old iPadmini, but I can not find a inductor 240ohm 0.2A, would you please advise the inductor can be replace by a SMD resistor 240ohm too?
完成的
添加一条评论
2个答案
已选择的解决方案
Aaron Teter, that is reference designator FL7500. It is a 240Ohm 0.2A filter (fixed inductor) in a 0201 package. Something like this will work.
这个答案有帮助吗?
得分 5
2条评论:
Just wondering how you figure this information out. Your answers are always useful. Thanks for your help.
完成的
Can you please tell me if i can take this filter out from diffrent device.I have iphoen 5s,6 and ipad 3 monther board.If yes can you please guide me.
完成的
添加一条评论
You have a lot of exposed ground plane here. Cover that with a conformal coating before replacing your filter. Don't allow any solder to adhere to that ground and short your gas gauge line
这个答案有帮助吗?
得分 2
1条评论:
Someone make jumper? Give some idea please.
完成的
添加一条评论
添加你的答案
Aaron Teter 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 12
总计 2,272
