跳转到主内容
加入维修社区 - 创建账户
Google 品牌旗下的改进型第二代平板电脑,配备 7 英寸屏幕。
Why won't my computer recognize my device?
When I plug my tablet into my computer with the USB cable, my computer doesn't seem to recognize the device. What are possible causes for this and how can I solve it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
The problem you are having could be due to a number of reasons such as a faulty USB port, cable, or Micro USB board or un-updated software. Please visit the Nexus 7 (2nd gen) troubleshooting page for possible solutions to your problem.
这个答案有帮助吗?
得分 0
添加一条评论
Here is what worked for me; After I initially my tablet to my computer it worked fine until my computer updated. I tried everything except removing updates because I had no idea which was the problem. What worked was; with my tablet connected to my computer by USB cable, open my Control Panel, open the Device Manager, find my tablet in Portable Devices(in my case EGQ307) and right click on the device. It gave several choices, most of which hadn't worked before, so I tried the only one left uninstall. I then followed correct procedures for turning off and disconnecting my tablet. When I reconnected my tablet my computer immediately found and loaded the driver and my tablet worked with no problems. I still don't why it does this (it has happened twice) but at least this fix works.
这个答案有帮助吗?
得分 0
添加一条评论
Are you a new Android user? If so, this will be an easy fix. After you connect the tablet to a computer a notification from the top will appear and ask if you want to trust the computer. Just tap accept.
这个答案有帮助吗?
得分 0
添加一条评论
i installed drivers so computer recognizes nexus 7. i read that previous drivers need to be uninstalled before installing again then nexus root toolkit should work perfectly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jillian Brown 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 13
总计 5,420
