跳转到主内容
加入维修社区 - 创建账户
发布于 2011 年 10 月。这是 GoPro 的第二代户外摄像机,被专业运动员、体育爱好者和核心玩家广泛使用。
Internal microphone does not work.
Hello,
I hum Problem with My GoPro Hero 2 from When I bought . Her microphone worked BY 15 days, since audio capture only with external microphone.
I saw several reports it can be the external connector that does not turn over the internal microphone , it proceeds ?
Is there any chance of getting the microphone and not the connector ?
thank you ,
Melvin Aster
from Brazil
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Did you plugged external mic into your camera?
If yes - it is common problem in some versions of hero2.
You can change (upgrade or downgrade) firmware - there is no specified version that is works, you have to try.
Then you should do not connect any external microphone (because camera will lock again on external mic).
Some versions of hero2 works good on latest firmware (you can use external or internal mic), but some also locks at external mic.
No known workaround for this issue.
Update (10/27/2015)
Also it is possible that mic cable is broken - you can simply fix it as shown in this tutorial (speaker replacement), but by mistake someone called it speaker while it is internal mic :)
Also mic can be broken, so you need to buy new one.
这个答案有帮助吗?
得分 0
添加一条评论
here is a link to the hero2 mic:
http://www.ebay.com/itm/GoPro-HD-Hero-96...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Melvin Aster 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 26
总计 1,886
