跳转到主内容
加入维修社区 - 创建账户
Roomba 650 是 iRobot 于 2012 年 8 月发布的一款第四代扫地机器人。该设备无需动手,可通过编程实现自动清扫居家环境。它几乎不需要手动操作,彻底改变了家庭清洁方式。
Why does Roomba 650 turn off before returning to charging station?
I programmed my Roomba 650 to clean at night, and it used to do its job, then return to its charging station. Lately, however, it has been ending its cycle somewhere else, like along a wall or in the middle of the room. I finally realized the other day that it wasn't finishing the job, it was dying before it got far from the charging station. How can I fix this? I'm not getting any error messages.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
pretty lousy device if battery is bad after only 4 months since purchase
由完成的
添加一条评论
4个答案
已选择的解决方案
Hey Charles,
According to the Roomba 650 trouble shooting page there could be multiple issues with your roomba. 1) Your target station is too far away or 2) There is an issue with your batttery. To fix the first issue you should move your home station to a more central location. For the battery problem I would suggest cleaning the nodes on the battery first then start to think about buying a replacement battery. You should check out the troubleshooting page at
iRobot Roomba 650 Troubleshooting
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题。
Try changing the battery. http://www.bestbatt.com/iRobot-Roomba-80...
Here's a rather poor but sufficient guide to do it: https://www.youtube.com/watch?v=khIVzbaD...
这个答案有帮助吗?
得分 0
添加一条评论
There may also be an issue with the charging station.
My Roomba does not return to the charging station. When placed there manually, Roomba does not charge. Unplugging the charging station and charging Roomba directly works. I then reconnected the charging station to power and measured the voltage across the spring terminals. No DC voltage could be measured. I unplugged the charging station and cleaned the terminals with a Q-Tip and rubbing alcohol. No change in the measured results across the terminals.
Question: How do I dismantle the charging base? I managed to unsnap all but one centre retainer.
Has anyone serviced the charging base?
Thanks in advance.
这个答案有帮助吗?
得分 0
3条评论:
A quick follow up...
I managed to open up the charging base. There is a 3rd fastener under the 'rubber' padding. You will need a long neck screwdriver to reach the head of the fastener.
The voltage I measured at the charging contacts is actually a steady 2.9 VDC. Does anybody know what a 'normally functioning' charging base should be outputting?
由完成的
The Roomba battery is 14.4 VDC, so you should be measuring at least that much. The specs should be printed on the transformer.
由完成的
Same problem and I also measured 2.9V on the charging base. 2.9V might be normal in unloaded state. The charger ckt card might do this to limit initial current until health of battery can be verified. Has anyone checked voltage while docked to a battery?
由完成的
添加一条评论
Hi,
My brand new Roomba 980 suddently stops moving. No error code, no sound, all lights go off.
The app says it is still cleaning.
It makes a sound when I pick it up.
Any idea?
这个答案有帮助吗?
得分 0
3条评论:
I’m having the same issue. Roomba 980 randomly stops. App says it’s still cleaning.
由完成的
the same for me and after while appication is saying i’m not on the same wifi as roomba. after manually switching on there is no entry in cleaning diary.
由完成的
I rebooted it last night and so far today there hasn’t been any problems. It finally completed an entire cleaning cycle without randomly dying (and it always died about 60 mins into its first run in the morning) and it returned to home base to get charged. I’m crossing my fingers it’s resolved.
由完成的
添加一条评论
添加你的答案
Charles Ward 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 39
总计 35,508
