跳转到主内容
苹果推出的面向个人消费者以及教育市场的笔记本电脑产品线。 iBook 系列包括 iBook G3 Clamshell,G3 12寸,G3 14寸,G4 12寸,以及G4 14寸。
What is the model number of my iBook G4?
There is no printing on the bottom of this iBook G4. How else can I find the model number?
I am trying to replace the DC in. The iBook doesn't always charge up when it's plugged in. Since I've replaced the power adaptor, I believe the problem is in the DC in.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
已选择的解决方案
Hi! If you have a 12" iBook G4, this is the DC-in you need:
http://www.ifixit.com/iBook-Parts/iBook-...
And if you have a 14" iBook G4, this is the DC-in you need:
These parts are generic across iBook G4s, the only factor being screen size (which determines the length of the DC-in cable). The G4 DC-in is not to be confused with the G3 DC-in, which has a whitish plug instead of the black plug on the G4 version.
Thanks
这个答案有帮助吗?
得分 2
添加一条评论
Under the Apple menu, select "About This Mac...", then click "More Info..."
this will launch System Profiler. Unfortunately the common model name (e.g. something like "A1054" for an Early 2004 iBook) will not be listed by System Profiler, but other useful and uniquely identifying info will be shown there.
you can then cross reference that info in the handy app called Mactracker. knowing a few pieces of info about your machine, e.g. the processor speed and general model type(e.g. iBook) will usually lead you to the specific model. There's also a unique machine identifier shown by System Profiler (e.g. "Powerbook6,5") which can be searched for in Mactracker to give you the more commonly known model name
这个答案有帮助吗?
得分 1
添加一条评论
Unfortunately, that bottom case is the only place the model number specifically is printed.
If you flip up your keyboard, what is the writing near the serial (it should say something like iBook followed by the screen size, followed by the processor speed, followed by the RAM, followed by the hard drive capacity, followed by the type of optical drive...)?
We can ID your machine from this info.
这个答案有帮助吗?
得分 0
2条评论:
How do I flip up the keyboard? Do I start following the instructions for taking the laptop apart as laid out in the instructions for switching the DC In?
完成的
Sorry for lack of info on my part! To flip up your keyboard, follow step 3 (you don't need to do steps 1 or 2 in this instance).
完成的
添加一条评论
Look under the keyboard
这个答案有帮助吗?
得分 0
添加一条评论
Try look under the battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Roman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 6,284
