跳转到主内容
A 35mm FD-mount single-lens reflex camera introduced in April 1984 as the second in Canon's T series.
9 个问题 查看全部
Attempting to take a shot, but buzzes, followed by beeping.
Just picked up a Canon T70 from a thrift store, and wanted to test it out. When I initially checked to see if it would take shots, it just buzzed. After the buzzing finished, the camera would beep repeatedly.
The battery level appears to be fine, although I have not had the chance to replace them. Looking online, I heard that it could be that the motor has seized up.
Does anyone have any experience opening up one of these cameras and adjusting/lubing the gears? Any tips?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
Same problem you find answer?
这个答案有帮助吗?
得分 0
添加一条评论
Have a working one. After a long time in storage, motor sounded like it was agonizing to advance the film, but after 2-3 rolls of films it went back to the happy sound I remembered from its youth. So motor seizing up could be an issue.
I also have another T70 I just got for future use as spares, same problem as nuget48. I downloaded the service manual (google for it, its freely available) that shows how to get to the motor. I will first try to move things from the outside - nudge the rubber take up reel to see if I can free anything, and if its not helpful will try to get to the motor when I have some free time, I will let you know if the problem was solved.
Another thought: since the shutter did not operate as well, it could be stuck on that. maybe I should first check the shutter.
anyway I will have something to play with :-)
这个答案有帮助吗?
得分 0
1条评论:
I know it has been over six years, but I, and many others have this exact issue. Could you update us on the spares camera?
完成的
添加一条评论
添加你的答案
nuget48 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 47
总计 2,875
