跳转到主内容
加入维修社区 - 创建账户
LG Optimus G 发布于 2012 年 9 月 19 日。这是一款由 LG 电子设计和制造的智能手机。在美国,该机型由 AT&T 和 Sprint 提供。AT&T 版本(E970)配备 800 万像素摄像头,Sprint 版本(LS970)则配备 1300 万像素摄像头。
How to get back the IMEI
My LG Optimus G has lost the IMEI after dropping from the chair. The IMEI in My Phone Identity menu said "Unknown" and so did the IMEI SV. The networking is normal, I can access the internet but I cannot have the phone call although the phone has simcard and memory card. My floor is made of ceramic. What can I do to repair my phone.
A repair shop told me that the hardware is the cause, not the software. But they don't have this kind of hardware.
If the hardware is the cause, could you please let me know what is it, what is the product code, eg, so that I can identify it and buy it online.
Thank you,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
9个答案
已选择的解决方案
It is not a hardware fault. IMEI is a file in root. use imei writing tool and write the original imei.
Try below steps,
In the dialer , type- *#197328640# or *#*#197328640#*#*
>You will be prompt into the Command mode, On the screen provided , Select on Common , normally option 6
> Now Select (FTM) Option 1
>FTM is for debugging and testing .,(Field Test Mode)
>If (FTM) is on, you will have to turn this OFF
>As soon as your turned this off your NULL or altered IMEI number will be restored
这个答案有帮助吗?
得分 3
添加一条评论
i have lg MS500 ,showing imei null.
how to change imei no back to original?
Update (08/22/2016)
i tried the above but not working on my phone too.
can any one sujjest what to do?
这个答案有帮助吗?
得分 1
添加一条评论
I lost my phone (LG optimus G pro) and I know it IMEI number of my phone. I want to find my phone is location. please assit me. Thanks
这个答案有帮助吗?
得分 1
添加一条评论
yes this a hardware issue.
这个答案有帮助吗?
得分 0
添加一条评论
this not working on my phone
这个答案有帮助吗?
得分 0
添加一条评论
not working to my LG P970, do I need to insert a SIM card?
这个答案有帮助吗?
得分 0
添加一条评论
My phone is screen lock i have no mobile box how can i see my phone imei model no LG Optimus G E975
这个答案有帮助吗?
得分 0
添加一条评论
I've never heard of something like that happening. Are you able to put in the IMEI manually? The IMEI and other numbers may be written near or under the battery. Have you tried a Factory reset?
这个答案有帮助吗?
得分 0
添加一条评论
Check if your Baseband is not Unknown,restoring IMEI is easy.
If Baseband is Unknown then you will need nvram from working phone (same model).After you get Baseband root your phone and use "MTKdroidTools"
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tin trinh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 30
总计 25,965
