跳转到主内容
加入维修社区 - 创建账户
也被称为 Sony Ericsson Xperia Nozomi、Sony Ericsson Arc HD。
How to merge Internal memory and Device memory?
Hi,
Sony Xperia S LT26i, has Device memory of 1.97GB. However there is 25GB of Internal Storage memory. Device memory is so small that more than half of it is occupied by Android, leaving very small space for applications. This in-turn slows up the device as there is very little space is remaining. I want to merge the both the partitions (Device memory and Internal memory). Can you please help me on this. My Emailid is: gaurav.whitelotus@gmail.com.
Thanks in advance!
Gaurav
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
3个答案
最有帮助的答案
Hey,
It *IS* possible, thanks to XDA Dev mickybart.
Not easy process at all though, check this guide on XDA. Make sure to flash Android 7.1 in the end (https://forum.xda-developers.com/xperia-...)!
Your warranty will be void by doing this. If you run into problems, do not hesitate to ask at that forum (the 7.1 ROM thread.)
PS: Rooted phone is necessary :)
Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
Hi,
I have the same problem, the only way that i found is through rooting the phone and then using an app called "Move app to SD card".
这个答案有帮助吗?
得分 0
1条评论:
can't move to SD card, any other solution?
完成的
添加一条评论
Unfortunately this can't be done. The 2GB internal is actually the RAM and is where the apps actually run and will be occupied as you stated. The 25GB is like the hard drive of a computer. The 25GB is only for storage of apps and data. Try running an app that let's you force close apps (Clean sweep or 360 security) and has the added bonus of cleaning the junk off of your device. I run 360 on my phone and it keeps it running really fast.
这个答案有帮助吗?
得分 0
2条评论:
Inncorect!!!
Sony xperia s have 32GB ssd but it's flipped in two partitions( one for the system and apps but other for other things).
And this phone only got 1GB of RAM.
完成的
Why not provided SD card available
完成的
添加一条评论
添加你的答案
Gaurav Singh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 10,316
