跳转到主内容
机器可读指令,可以指导计算机处理器从互联网上下载和渲染“猫”的图像。
Run DLL error in Windows 7?
I get this error:
C;\Users\NewCanaan\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll
What is it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Found this on the web, looks like malware issue.
To resolve this, download AutoRuns and save it to your Desktop.
Create a new folder on your hard drive called AutoRuns (C:\AutoRuns) and extract (unzip) the file there.
Open the folder and double-click on autoruns.exe to launch it.
Vista/Windows 7/8 users right-click and select Run As Administrator.
Please be patient as it scans and populates the entries.
When finished scanning, it will say Ready at the at the bottom and list all entries under the Everything tab.
In the top menu, click File > Find... and type the file name (backgroundcontainer.dll) related to the error message, then click Find Next.
Alternatively, you can scroll through the list and look for any entry related to backgroundcontainer.dll and conduit.
If found, right-click on the entry and choose delete.
Exit Autoruns and reboot your computer when done.
这个答案有帮助吗?
得分 1
添加一条评论
Hi, Great info! Could the same work for ... C:PROGRA~1\Common~1\System\SysMenu.dll? The dll system files?
I have Windows 7 and continue to get error RUN DLL--- Page unresponsive? The Specified Module could not be found: Have tried... "taskschd.msc.... CMD--- "SFCC/SCANNOW--- does not work.
Part of the problem is certain videos do not open after clicking link. For example opening a video link for an information topic..i,e real estate investing?
这个答案有帮助吗?
得分 0
添加一条评论
1. You have to operate as an administrator, regardless of the steps you are going to do with regards to Laptop or computer.
2. The particular techniques we have discussed earlier are often precisely the same for each and every Windows type, with small differences.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
smburke62 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 287
