跳转到主内容
加入维修社区 - 创建账户
Motorola Moto G (第二代),也称为 Moto G2,是 Moto G 的 2014 年继任机型。Moto G2 配备了 5 英寸 720p 显示屏和 Qualcomm Snapdragon 400 处理器。型号包括 XT1045、XT1040、XT1039、XT1069、XT1068 和 XT1064。
micro usb port broken...needs replacement
Hello,
My moto g 2nd gen phone charging port is broken. I can clearly see the inside of the port is broken and needs a replacement. Could you please let know the guide for this? and where can i purchase the replacment parts for it?
Thanks,
Anand
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
5个答案
已选择的解决方案
This is a difficult one, I would suggest taking it to a phone repair shop.
https://www.youtube.com/watch?v=ycER7MH6... - the link is a video on taking apart the phone itself if you wanted to attempt to repair this yourself.
I am not sure where you could buy a charger port, hence why i suggest a phone repair shop as they would have the equipment and hardware needed to repair this.
Sorry i couldn't be much help, but if this has helped you in any way please accept the answer or score the post.
Wish you all the best
这个答案有帮助吗?
得分 4
添加一条评论
http://www.etradesupply.com/motorola-mot...
Charging Port for Moto G2 .....
这个答案有帮助吗?
得分 1
添加一条评论
Moto G2 charging port locates on the motherboard by soldering, so it is hard to replace it by DIY repair work, you'd better send it to the repair shop for help.
这个答案有帮助吗?
得分 0
添加一条评论
My local phone / computer repair shop just confirmed for me that the solder used to connect the micro USB port to the motherboard is a higher temperature solder than what's used for the other components, intentionally to make it darn hard (nearly impossible) to replace this “wear item” in order to sell more phones.
This shop won't even attempted this repair any longer after several failed attempts and they consider themselves experts at micro soldering.
Sucks that phone companies have all figured out this dirty little bit of truth (that we are not surgically precise in our connecting and disconnecting our cords) and so they are getting away with building in and selling planned failure.
这个答案有帮助吗?
得分 0
添加一条评论
i have motorola moto g2 xt1068
my phone have 2 problem
1 my socket charger of board is broken that connect to pc and charger but not charging
2. my phone is starting up and after 1 minutes shutting down automatic
now i have one question that if i change my socket charger of board my shutting down problem is fix?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anand 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 24,933
