跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Why iPhone 4 will not charge?
My GSM iPhone 4 will not charge. I installed a new battery and all functions work normally except the battery will not charge and drains to zero. I'm using a cable that works properly with my iPad 2. I replaced the dock connector and installed a new battery but this did not fix the problem. Before the new battery fully drained I did a full reset, but this also did not fix the problem. There was not enough battery life to try a software update. I also tried reseting by depressing the home and power buttons until reset. Any suggestions on what else to try? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you tried another battery?
这个答案有帮助吗?
得分 0
1条评论:
Yes, the phone will work with a new battery, other than of course it will not charge.
完成的
添加一条评论
Hey Mark, due to the fact your iPhone is a mini computer, it makes it a sensitive piece of equipment. Your more then likely having a motherboard related issue. At this point your options are limited.
A.)Take it to a professional shop to have it properly diagnosed.
or
B.) You can try cleaning the motherboard with some 91% alcohol and a toothbrush, very gently do this. Clean the entire thing then dry it thoroughly with a blow dryer if possible. Dust and dirt accumulates after awhile of using these devices (2-3 years).
If that does not help, try known working charge ports and batteries, its possible the ones you tested with were defective.
Other then that, your going to need some professional assistance.
Good luck my friend. Let us know how it works out.
Josh.O
这个答案有帮助吗?
得分 0
1条评论:
Many thanks Josh, I will try cleaning per your directions.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 81
