跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
best tool for standoff screws - stuck standoff screws
Hi,
Been reading posts on the standoff screws and removal of the screws when looking to remove the logic board.
I have been using a small flat head screw driver to remove these however I have been coming across some extremely tight screws which when using this method, I end up spending a good 30-60 mins removing two screws as the force needed to move them means the flat head driver slips,
Does/has anyone come across this problem at all? is there a tool that people use specifically for these screws? i've read about grinding down a phillips screwdriver to make it flat to get a good ground in all four connections. what do people think?
Thank you
Danny
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
Here's what you need:
[关联产品丢失或禁用: IF145-343]
这个答案有帮助吗?
得分 5
2条评论:
You can also buy a standalone driver with that same tip. I have one and it is lightyears better than using spudgers or flatheads. Its worth the couple of bucks to buy one.
完成的
Hey! My standoff hex nut that I am trying to remove in my iPhone 6S is completely smooth! It does not have a slot for a flathead to fit anywhere. Any ideas?
完成的
添加一条评论
Those things are extremely aggravating. I don't know why someone hasn't invented a screwdriver just for them
I have found the the round side of a metal spudger works really well when you have plenty of room and the pointed side works ok (better than a flathead screwdriver) in tighter spots.
http://www.mobiledefenders.com/metal-spu...
这个答案有帮助吗?
得分 1
2条评论:
THEY DO! after a lot of digging around i found a screwdriver on ebay from china that is specifically for these stand off screws!! its incredable! best £10 i ever spent!
完成的
I worked on one for about 10 minutes with all of the different flat head attachments that come in the fixit kit and could only get it off after seeing this post and using a metal spudger. Thank you!
完成的
添加一条评论
If you use a bigger flathead screwdriver, you should get more pressure? Or find a flathead screwdriver with a bigget bit so that it fills up the track in the screw?
这个答案有帮助吗?
得分 0
添加一条评论
I use the standard one you get in most repair kits and it works fine, just position it perfectly
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
danny 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 81
总计 13,081
