跳转到主内容
加入维修社区 - 创建账户
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
LCD Problem After Replacement
I have replaced many Ipad Mini digitizers however the last 4 in a row I have replaced after I test them they have damaged LCD panels and Ive had to replace them. What can I be doing wrong Im doing everything the same as before nd have just started having this happen. I remove the lcd tape carefully and dont cut anything I need help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If the LCD's come out broken, I'd say you are not careful and gentle enough when removing the LCD from the iPad Mini.
I recommend that you carefully follow iFixit's guide until step33. Then for steps 34 to 41, be very patient and to separate the LCD from the metal plate: instead of guitar picks, use floss (or some similar thread) or a plastic card (credit-card shaped, but thinner and softer, such as the ones found in screen saver kits).
Good luck, tell me if this helped.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
greg24892 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 134
