跳转到主内容
加入维修社区 - 创建账户
1400 万像素相机。具有 12 倍光学变焦、48 倍数字变焦、光学防抖(OIS)、带立体声麦克风和自动对焦的高清视频拍摄功能。有红色或黑色可选。这款相机支持以下存储卡:SD/SDHC/SDXC/EyeFi(完全支持)。
My flash does not work
why doesn't my flash work?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Does it not work as in not fire, or not pop up?
If it doesn't pop up, there could be debris preventing it from working correctly. Check for debris and if you find any, clear it out with a soft cloth or toothpick or even a soft bristle toothbrush.
Also, if it isn't popping up correctly, it could be that the spring attached to the flash has either broken or come loose.
If the flash isn't firing then the bulb could be out.
Also, you should be able to go into the settings on the camera to make sure the flash is turned on, or that it is dark enough where you are trying to take a picture for the flash to actually fire.
Check out the troubleshooting guide for more information.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Henry Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 41
总计 1,484
