跳转到主内容
Headphones released in 2011 for use with XBOX 360. They are identified by the model number X12.
26 个问题 查看全部
How to fix audio jack at the end of the cord?
The small mm jack at the end of my headset has come undone from the plastic seal around the wiring. So the green jack kind of just flops around. Now there is no sound coming to the headphones whenever it is plugged into an audio source. Is there any way to fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Matt Thomas, yes there is . The green 3.5mm jack is your audio, so you obviously have some broken connection. Replace the jack the same way you would on a regular headset. Take a look at this guide to see how to replace an audio jack. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Matt Thomas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 20,320
