跳转到主内容
2.3L 4cyl or 3.0L V6, 6th Generation
426 个问题 查看全部
Where is the computer to the transmission located?
The car runs fine but after a while of driving it goes from high gear to low and I can stop and put it in park and cut it off and back on and it will change fine for a little while. I had this similar problem in my 1992 and all I had to do was replace the transmission computer and now it works perfectly so I was thinking this one may have the same problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
6条评论
What model and what year?
完成的
1999 Honda Accord.
完成的
Well I took it out and the part has SRS on it instead of PCM is that still the right part?
完成的
Absolutely NOT correct. The SRS unit controls the air bag system and ONLY the airbag system.
完成的
Where is the pcm computer
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
Lamica Stone, the electronic control system consists of the Powertrain Control Module (PCM), sensors, and six solenoid valves. Shifting and lock-up are electronically controlled for comfortable driving under all conditions. The PCM is located below the dashboard, under the front lower panel behind the center console.
这个答案有帮助吗?
得分 2
1条评论:
Also pulling the fuse, resets the computer as I understand it. But as you described.... I wound up redoing the Tranny. PCM is easy to get to and remove. However, KNOW!!! they are keyed to the ignition! Can't put a new one in unless Honda hooks the new one up to a computer and downloads your configuration into it. You'll be DEAD. $100 is the charge. VIN will reference the correct part number. But it is on the side as well (even better) There's a couple of excellent cross reference sites. I may even have a PCM
完成的
添加一条评论
添加你的答案
Lamica Stone 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 50
总计 30,847
