跳转到主内容
This Power Mac G4 has Mirrored Drive Doors.
80 个问题 查看全部
问题已关闭
What is the best method of removing scratches from the case?
I have purchased a PowerMac3,6, (MMD G4). The tower's case (not the doors) has a number of fine scratches, some are deeper than others. What is the best method to buff out these scratches while keeping the case's mirror-smooth finish?
Thank you,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Wil, are we talking about the Acrylic sides?
完成的
添加一条评论
2个答案
已选择的解决方案
Wil, fine scratches can be removed with a mild abrasive polish such as Novus #2, or Novus #3. Heavier scratches, such that you can feel with your fingernail, will require some elbow effort to remove with a bit of sanding and buffing. A series of grits (150,400,800) followed by a buffing wheel and available buffing compound, this should restore your case. Check on here to get an idea of how its done. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
1条评论:
Thank you. That is more or less what I was thinking.
完成的
添加一条评论
最有帮助的答案
I would honestly just get a new case, they are not that hard to instal if the scratches are that bad. If they are not some Pledge works great.
Please mark me up if this helps : )
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 790
