跳转到主内容
Canon PowerShot A series point and shoot camera released in 2006, with a 6.0 Megapixel camera and 4x optical zoom lens.
6 个问题 查看全部
recently started taking solid black pictures
up until recently, my camera works perfectly. Then about a week ago, it started taking solid black pictures. When trying to take a photo I can only see black in the screen. However, I can see previously taken pictures in the screen. I saw this problem listed under the S series. I tried the resolution by looking down the zoom lens,but I can see the "Flicker". Could this be something else? How can I fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Shelly, could be that the OPTICAL UNIT is defective. (The shutter in the LENS part is not opening). It is also possible that you have a CCD sensor error. Usually a replacement of the lens assembly will resolve it, but there is always a possibility that it is an issue of the CCD circuitry on the mainboard. I'd start with a new lens. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shelly 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 201
