跳转到主内容
Garments that keep you warm on brisk days and dry on wet days. Repair difficulty ranges from simple tear patching to more complicated baffle repair.
How to repair a tear on the down jacket?
While hiking in Costa Rica past week, wearing my Patagonia down jacket, I got about two inch tear on the jacket near the shoulder by a thorn. The jacket is only a month old. Is there any fix I can do that will preserve the aesthetics?
Thanks a bunch.
Pete
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
4个答案
已选择的解决方案
Here's the guide: 用修补胶带修补绝缘夹克
这个答案有帮助吗?
得分 2
添加一条评论
Hey Peter, I have a 17 year old down jacket (it's a Marmot, but same construction as Patagonia) and it has a few repairs that are over 10 years old and still holding strong. Aesthetically, I believe the best fix is to buy some Tenacious Tape, which is made by Gear Aid, and cut a patch that has rounded corners and extends past the tear 1/4-1/2 inch past the tear in all directions. It is applied like a sticker (peel the backing off and smooth it on the fabric) and comes in a variety of colors including clear. I like to choose a different color tape that is complimentary to the color of my jacket for repairs, but if you want to preserve the original look of the jacket, then use a matching color or clear tape. To make the repair extra bomber, brush on a thin coat of Seam Grip (silicon nylon repair goo) around the edge of the tape. It's rad that you're interested in repair. This is cheap, easy, works well, and looks remarkably good.
这个答案有帮助吗?
得分 1
添加一条评论
Another repair tape that I've used is clear "Gorilla" tape and follow the install directions from Nate.
这个答案有帮助吗?
得分 0
1条评论:
I vote for clear tenacious tape because I usually like a contiguous aesthetic as well. But after working in Antarctica for a season it was easy to see that folks wore their duct tape and mismatched color tenacious tape like a badge of honor!
Pro tip - cut a circular shape of tape - the abscence of corners means your tape will adhere better and less likely to pull off
完成的
添加一条评论
Id recommend a product called fixmytear. It's a repair tape which sticks very well to vinyl, canvas and most other surfaces. I ordered it from their website, www.fixmytear.com. Absolutely life saving tape.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Peter P Devon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 35
过去 30 天: 171
总计 24,010
