跳转到主内容
Backlight not working through screen but work on keyoard
Hey I spilled some water on my laptop and was wondering should i get a new screen or logic boad or invertor cable for my macbook pro late 2011? The backlight works through my keyboard and when I use a torch through the apple logo i can see everything. I can also see everything when I use external monitor and everything works fine on my computer except the backlight. Thanks for any help in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
4条评论
After some more research I figured out I need the wled driver on this macbook. Where can I get a replacement part for it? I can solder it myself.
完成的
Basically I need to resolder in the qfn. But what qfn do I need?
完成的
What's a "qfn"?
完成的
After checking the continuity with the multimeter I think its either the driver chip or just the LCD itself. I'm not sure which one it is though
完成的
添加一条评论
2个答案
已选择的解决方案
Ali, most often it is the backlight circuitry on the logic board that shortens out. you computer does not have an inverter cable per se and the LCD is most often no affected. If you want to replace a part, I'd go with the logic board, but check your old one first. Clean it appropriately with isopropyl alcohol and check the fuse and other components, for any damage. Check your display cable connector and make sure it is seated properly and check for damage on it as well.
update
Fuse and LED driver location marked. The driver is a APP001A and that of course means it is Apple proprietary so no data sheets available. It might also be impossible to get a replacement. You'll have to find some information about Apples LED driver and see if there is a compatible one from TI for example.
这个答案有帮助吗?
得分 4
10条评论:
Thanks but I'm willing to give a new wled driver chip a try before I buy a logic board since its soo much cheaper.
完成的
I agree with oldturkey. You should first make a visual inspection of the board and carefully check the LVDS connector and socket for any sign of electrical short on the cable end and in the socket. Also verify the continuity on the backlight fuse. If you're lucky you may just have to replace this fuse cause removing and replacing the wled driver chip is not a newbie task. You need a hot air station and the technical knowledge to perform this delicate job.
完成的
After doing a visual inspection of the board I'm pretty sure its not the LVDS commector. I'll try to replace the backlight fuse instead and see how it goes thanks guys.
完成的
Which fuse do I need? Any link to them would be greatly appreciated.
完成的
Alim, we do not know yet if you need the fuse. Lets start with this, do you have a multimeter to test for continuity?
完成的
显示更多的5条评论
添加一条评论
Before replacing the fuse isn't there a way to TEST the fuse with a volt meter before replacing it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 6
总计 1,482
