跳转到主内容
Hewlett-Packard于1993年开始制造个人笔记本电脑。
3332 个问题 查看全部
HP 650 Notebook display turns from black to white after power-on?
After powering on my HP 650 notebook the display shows the HP logo. Then the display gets black and slowly turns from black to white (or grey more or less).
See attached video:
Then the display stays something like black-white-checkered (this image shows it a little bit:
I can attach a external display via VGA connector. The picture on the external display is right.
So graphics card doesn't seem to be faulty.
Somebody told me that thsi problem maybe can be solved by changing a transistor or resistor or something like that. But couldn't find any evidence for that on Google :-(
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Add an image showing us the complete screen and what it displays. From your description it sounds like a bad LCD driver circuitry
完成的
oh, I recognised, that the iFixit Media Manager didn't insert my video that I uploaded. Instead it choose some random image (first image in my posting).
I have a MP4 video showing the full screen and you can see how it looks when I power on the Notebook. But how can I post this video???
完成的
uploaded the video to Videobin.org:
http://videobin.org/+8ej/b8n.html
完成的
添加一条评论
1个答案
已选择的解决方案
MausP, attach an external monitor and see if that will display properly. Right now your LCD does not get a signal, the white light is your backlight. This could be a GPU error or and LCD error. If an external monitor works, replace the LCD. If an external monitor does the same thing, you will need some motherboard work.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
MausP 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,071
