跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone 3GS Battery doesn't take charge
Hi everybody !
One of my friends has given his 3GS to me so I can try & repair it. His symptoms are quite simple : when he pluggs the iPhone either on a wall or a USB plug, the battery appears (like when you're plugging in an iPhone that ran out of battery) but it remains red (it doesn't charge) and the iPhone doesn't start.
I'm planning to replace the battery and I'd like to be sure that this doesn't come from another problem.
Any answer would be welcome !
Thanks in advance
Vincent
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Vincent Monteil , here is my answer to similar question. " I would replace the battery first, next check the battery contacts with a multimeter and the USB cord plugged in. See what voltage you get on the contacts. It is easily possible that you have some pins corroded, bend, or broken. Also check for debris in the dock connector. If your dock connector checks out okay, check the fuses and see what you get. Check the image posted for fuse location (left is 3G right is 3GS.) Dimensions are 3GS fuse is 2mm x 1.20mm and the 3G one is 1mm x 0.30mm approximately.) Based on these specs the appropriate part number (Littelfuse Inc) seems to be 0435002 for 3G and 0467002 for 3GS. A small note about 3GS: the above fuse size is 0603, a little smaller of the original. The correct size is 0805 (2012 Metric), but unfortunately Littelfuse doesn't have this size available. An alternative could be MFU08052 from Vishay/Beyschlag Inc." Hope this helps, good Luck
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Vincent Monteil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 187
