跳转到主内容
MacBook Pro带有15寸屏幕的型号
8253 个问题 查看全部
New Battery Charge Level Incorrect
Hello,
I ordered a new battery from this site ([关联产品丢失或禁用: IF161-081]) for my MacBook Pro 15" Early 2011.
After putting the new battery in, I pushed the battery charge level button to see how much it was charged. It showed 4-5 lights. I powered on the laptop and OS X showed the battery charged at 45% and that it would take 2-3 hours to fully charge. I disconnected the power cable and it immediately shut down.
Seems to me the battery charge level is completely off. I let the battery charge fully, and got about 36 minutes of usage time before the laptop shut itself down. I reconnected the power cable and powered back on my Mac, and it showed the battery level at 75%, charging!
So what's the deal? Is the battery defective? The sticker on it from iFixIt showed 0 cycles.
Update
Here are the Coconut Battery results. If I charge the battery up fully (94% or so), it will last for about 20 minutes before suddenly shutting down. I went through three cycles of that yesterday, and it seems to last 20-30 minutes each time. Plugging it back in starts it up again right away.
The web results seem to have a mix of data from old battery and the new one, don't know if that helps:
http://ccbonline.coconut-flavour.com/ind...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Download and run Coconut Battery. It will give you the actual number of cycles, the original maximum charging capacity and the current capacity. Armed with this information we can better tell you what's going on.
http://www.coconut-flavour.com/coconutba...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Sccoaire 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 628
