跳转到主内容
加入维修社区 - 创建账户
这款 16 GB 的 Oppo Find 7a 发布于 2014 年 4 月,是 Oppo Find 7 的低配版。要区分 Find 7a 和 7,请取下后盖及电池。在电池放置在手机内部的位置,应该有两张序列号贴纸,上面印有 X9000。
Why does the back panel not close fully?
I took apart the phone, and now the back of the phone doesn't fit completely. How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Putting the back panel on your device works in the opposite way as you did taking the back panel off. Start by pressing in the bottom sides of the back panel onto the phone and continue up the phone until you have completely attached the back panel onto the phone.
Note: If you used a replacement guide that required you to take the power button off, make sure you place the power button on BEFORE adding the motherboard (following the guide backwards). Not doing so will result in you not being able to fully close the back panel due to the power button not being placed where it needs to be.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joe Hanacek 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 16
总计 334
