跳转到主内容
加入维修社区 - 创建账户
2004 年生产/2 加仑储气罐/无油压缩机/型号 FP204800/此款压缩机的维修非常直接。
Why is my compressor so loud?
When in use, my compressor is excessively noisy and sometimes rattles as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I took the shroud off mine WL611105AJ I took the shroud off the motor fan and when you toch it it squeeks I sprayed it with contact cleaner and it ran quite then stared squeeling again is the a part no for the bearing behind the fan it is in front of the brushes.
由完成的
添加一条评论
1个答案
Check to make sure the pump is level. Remove shroud and check for loose components in the compressor. Tighten all loose components accordingly. If the rattling still continues, it is most likely a problem with a bearing or cylinder in the pump assembly. You will need to replace the Pump Assembly.
Happy Fixing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eric 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 31
总计 1,646
